Question about Hoover F5858-910 SteamVac Vacuum
Wont power up - have checked all connections - Hoover F5858-910 SteamVac Vacuum
  • 40 Answers
It sounds like you have a break inside the power cord.
Posted on Aug 01, 2009
Power wont stay on
It sounds Kirby has a new model with a new type of switch go back to the shop you bought it , if you have not read the manual , a tip , 1 look how the dustbag is connected it must be good connected if not the problem is there , second the hose the hose must be connected good because if not the problem is there more options are not there for the master switch . if its controlled that the switches are god pushed in by mechanic parts of the dustbag connector or hose connector , it must run and stay on power the dustbag is the one that is the most probable connection what maybe not enough is turned to the motor housing have a stabil working on -off switch. if it not does made difference go immediatly back to the shop. with proof of purchase, you get an other new one if its a factory failure. or the powercable was accidentially bruised between a door or linger behind the powerplug and that why its faltering maybe.
Apr 21, 2015 | Kirby Vacuums
Spark caused vaccum to turn off
Some vacuums have a reset button you can push. Some have a fuse in the power line that may have blown. You will have to follow the power all the way through the vacuum checking the voltage at each switch, connection, etc. I often unhook the power & neutral wires from the motor and hook up a power cord with connectors on the end directly to the motor to make sure the motor is good. You must be very knowledgable with motors, switches, electrical testing, etc. If not this repair is best left to a professional.
Mar 03, 2014 | Dirt Devil Vacuums
The vacuum wont start
It could be many different things. Start with making sure full voltage is coming through the power cord, the switch and all wiring connections to the motor. If all power is ok to the. Motor you will need to check the motor to insure it is working properly.
Mar 01, 2014 | Eureka AirSpeed Gold Bagless Upright...
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
My Magic Blue wont power on.
there is a wire contact on your vacuum handle.
try to check all the wire inside your vacuum, or if you cant, try to call for an expert technician to check up your vacuum.
Feb 04, 2013 | Kenmore Magic Blue 24195 Bagged Canister...
I have an open in the black wire leading down to the carpet sweeper (after the handle), thus the motor wont turn on. how do i get to the wiring to re-run a black wire?
Did you test the wire with the switch in the "ON" position. If not, try it before opening the handle.
The problem is more likely to be a worn out or broken switch, including a reset switch.
Also try connecting the hose directly to the power nozzle. If it works, then the problem is problem a loose or burnt out connection in one of the wand connections. Check connections for discoloring.
Jan 01, 2011 | Kenmore 28015 Bagged Canister Vacuum
I have power to my orteck xl bagged unit but it wont
check the cord that goes from the handle to the brushroll housing. these usually go bad by the strain relief. also open up the handle and check to make sure the power cord wire didnt come disconnected from nthe switch, also a common problem. let me know if you need any further assistance
Jan 05, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Wont shut Off
its the power switch, hoover has had that problem for years. I'd take it to a vac repair shop, sometimes the wires that connect to the switch get burnt as well and should be replaced.
Sep 16, 2009 | Hoover U6630-900 WindTunnel Bagless...
Wont charge
did you try plugging in 560 driectly to charger then run it?
Dec 26, 2008 | iRobot Roomba 560 Robotic Vacuum
Hoover F5858-910 SteamVac Vacuum Logo
24 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
