Question about Audiovox Prestige Code Alarm Remote Alarm Protx6
Neither remote will work my viper 771xv so my truck is just sitting and im unable to start it at all without the siren blairing can anyone help me
    Sergeant:
  • 436 Answers
You may need to reprogram the remotes. you will have to get an engineer out to do it.
Posted on Jul 30, 2009
How to install the alarm speaker for a viper
from the siren 2 cables come out, one black and the other red, the red one goes to the siren output (brown wire)
Apr 02, 2014 | Remote Start System
The alarm doesn't horn
take off the siren and connect it to the battery, if it works check the alarm wiring. if the wiring is good check the output of the siren.
Mar 22, 2014 | Remote Start System
My viper 5701 alarm is having issues.
First thing is to trip the system to see if the siren works then. If it does, then perhaps you inadvertently set the chirp commands to silent. If the siren doesn't work when the system is tripped then that's your problem. You'll need to find the siren and troubleshoot possible causes. I'd start with the wiring but the siren could have simply gone bad. You should be able to test it easily with a test light or multi-meter.
Mar 19, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hi I have a viper 5701 it was working fine for about 2 years and today the car just stop beeping when I lock or unlock the car please help
Was this "beep" from the horn or a siren? The unit could be in valet. Look at the LED on the antenna. Is it on solid? If so the system is in valet. To remove valet, turn ignition on then off, press and release programming button on antenna.
If the LED is not on and, the "beep" came from the siren then, there is an issue with siren itself.
Jan 16, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Battery dead.when i try to boast the car alarm goes off and i can"t turn it off without removing boaster cables
Try manually disarming the system when you hook up the battery cable. After you hook up the cable ( the siren will be going), turn ignition on, press and release valet switch one time. The siren will stop and you will be able to start the vehicle. Test the remote. If the remote is not working, and the battery is good, try reprogramming the remote. Turn ignition on, press and release valet switch one time. Press and HOLD valet switch, press lock button on remote. You will hear a confirmation chirp when the remote is programmed. Turn ignition off. Test system.
Nov 21, 2010 | Remote Start System
Just baught a truck with a viper alarm, worked great then today i unlocked the truck with the viper remote and when i open the door the horn goes crazy for for about 1 min not the accual alarm! but at the...
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at jared@underground-audio.net if you'd like.
Nov 17, 2010 | 7752V Replacement Transmitter Supercode...
Remote program
Open door
Key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Feb 18, 2010 | Viper Security and Remote Start System...
Viper 771xv remote start problem
the led should blink a code that tells you why it shut down or failed to start
Jul 05, 2009 | Vehicle Parts & Accessories
2003 chevy trailblazer. alarm problem 771xv
CHECK THAT YOUR BYPASS POWER IS ONNECTED TO THE ACC.CABLE FOR IT WILL NOT DRAIN YOUR BATTERY
Jan 20, 2009 | Vehicle Parts & Accessories
Viper remote 771xv works, but gives three steady tones at regular intervals after using.
That means that your remote is not receiving a signal from the remote starter. That's a two-way unit designed to transmit(tx) and receive(rx) signals to and from the antenna or brain. If it doesn't do either one, the remote will give you three triple beeps.
Jan 01, 2009 | 791XV The 791XV is a 2-way Security and...
Audiovox Prestige Code Alarm Remote Alarm Protx6 Logo
241 people viewed this question
Top Prestige Appliances Vehicle Parts & Accessories Experts
xxxxxx xxx
Rocguy
Tim Marx
Tim Marx
Are you a Prestige Appliances Vehicle Part and Accessory Expert? Answer questions, earn points and help others
