Question about Miscellaneous
2001 Vermeer sc252 stump grinder wont hardly move forward or backwards. do I need to replace the drive motor or what could be the issue?
  • 1,389 Answers
Has a belt for the blade called a gates power chain and a belt the runs the hydraulic pump.just a common V belt check it, me thinks it's the problem, needs to be tight
Posted on Dec 21, 2017
Testimonial: "got a new belt what is the easiest way to replace this? I cant find any adjustments to loosen a pulley enough to get the new belt on? any help would be greatly appreciated. thanks again!"
SOURCE:
michigan man
  • 3533 Answers
SOURCE: my drivers seat wont move.
check the track for anything that have gotten stuck in it and then check the fuses and if all good the motor could simply be burned out get a 12volt tester and if the fuses are good test to see if you have power while pushing the button because it could be just a bad switch
Posted on Jan 15, 2009
  • 599 Answers
SOURCE: 1993 BMW Front seat adjustments
i have all the info you need..had to do this on my brothers care...short answer is the cables stretch inside their housings.. once seat is removed you trim the casing around the cables 1/4 and reinstall the end caps on each one to make them match their paired partner cables..stupidest thing bmw ever did having two cables to control each movement causing the chairs to twist and buckle like that..compare at $1000 to have qualified service do it for you...
Posted on Feb 26, 2009
chrischronic
  • 235 Answers
SOURCE: Power drivers seat does not move forward and backward
if thare is a clicking sound heard then the fuse is not blown so this means ether the seat motor or transmission has gone bad and you half to replace the hole seat track, cause i dont think servisable parts are available for this vehicle
Posted on May 05, 2009
  • 10 Answers
SOURCE: power seat issue
Get out your voltmeter, unplug the connection to the seat's motor, underneath the seat, and hit the switch. if youve got power going to the motor then youll need to replace the motor. If not, it's probably the switch. Also make sure the wires are not cut or damaged somewhere between the switch and the seat.
Posted on Jun 20, 2009
  • 50 Answers
SOURCE: The electric front seats both stopped moving
Check the fuse box for a blown fuse, both seats may operate on one fuse depending on the model of vehicle and the fuse may be located either under the dash on the drivers side or in the engine compartment on the drivers side.
Posted on Aug 21, 2009
Used Vermeer sc252 stump cutter. Just purchased and testing. During operation it sometimes jumps forward pulling into the stump and stops from too much feed.
I tried the service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Mar 22, 2018 | Heavy Machinery
How do I change the belts on a Vermeer sc252 stump grinder, the drive belt from motor to hydraulic pump broke and I need to replace it. thanks
loosen off the pump mounts or adjustment bolts so that then belts can be easily fitted / removed
The problem facing you is to get all belts the same (matched belts )
you will get these from a belt retailer or engineering shop
Matching belts are from the same belt stock or batch and will have a second set of numbers on them
for example you will see the first measurement as --for example -- A 1450 --indicating A section with a length of 1450 mm
so you can get say three belts each with that information but when fitted one belt will be loose all the time
you will need to check for a second identification on the belts something like 123 or a12x or simply 32b or what ever
when you find belts with the A 1450 and with matching second identification of 32B ( A1450 32b) then they are from the same batch and when adjusted all belts will carry the same load
because of the load on a stump grinder motor , the assumption is that there is at least 2 or more belts from the engine
Jan 05, 2018 | Washing Machines
How to tighten the belts on my sc252 vermeer stump grinder
How to get a Vermeer Product Manual
Vermeer manuals explain how to safely and efficiently use and maintain your Vermeer machine by referencing your Operation and Maintenance Manuals.
If you are the current owner of Vermeer used equipment, free replacement manuals are available by registering your used Vermeer machine. Your machine Operator's, Maintenance and Parts Manual may be available online. Replacement User's Guides for Vermeer Productivity Tools are also available to those registered and authorized to use the software.
Jul 21, 2017 | Heavy Machinery
Sc 252 /the wheels do not lock when cutting. what hydrolic part is the cause
Have you locked both diff pins in on the wheels or are they disengaged.?
Apr 07, 2016 | Vermeer 2006 Sc252 Stump Grinder
What do u need to replace besides battery for motor to power up?
trace the wireing from the switch,look in hidden area about 1 to 2 feet down from switch,is there a fuse link in line?--if so replace the fuse,--I have 12 years small engine,ill walk you thru it from here if you like,chuck,,check this and let me know,then if its not there or not problem we can move forward to safty switches.
May 25, 2014 | Kohler CH730S VERMEER STUMP GRINDER
Fuel fails to reach carb and prevents starting
Clean the fuel sock on the pump and connect a pressure line or air compressor to the fuel lines to blow out the clogged lines if that don't work then clean the jets to the carborator
Mar 23, 2014 | Vermeer 2006 Sc252 Stump Grinder
Engine won't turn off when ign switch is turn to off
indicates a faulty ignition relay
run the fault codes
Jan 28, 2014 | Vermeer 2006 Sc252 Stump Grinder
Vermeer 252 wiring diagram
I need a wiring schematics for a 352 Vermeer stump grinder
Jan 14, 2013 | Vermeer 2006 Sc252 Stump Grinder
Open Questions:
Miscellaneous Logo
431 people viewed this question
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
