Question about T-Mobile Wing™ Smartphone
Micro sd card
Hi, I incorrectly inserted a micro sd card and now it is stuck.Is there a way to open up the device and removing it?
  • 27 Answers
Re: Micro sd card
Look for a rubber cover on the phone and take it off and then unscreew it?
Posted on Dec 03, 2007
0 characters
3 Points
I have black jack..and wen ever i insert my 1gb micro sd,,it shows storage card not found,,,,so,can you just tel me the way to solve this issue....
try inserting a different micro sd card of 1gb in your mobile, if it gets work, then you could be sure that their is a fault in your that memory card which shows storage device not found.
it may got currupt.
or try formatting that memory card through a computer, then insert it..
it may will work, but if not then its time to buy a new memory card as that card is currupt.
Aug 18, 2011 | Samsung Blackjack SGH-I607 Smartphone
I own the r451c which has an mp3 player, but when i insert the micro sd and go to music player, i get a prompt that says no mp3, what am doing wrong
You have to load mp3s on the micro SD card via the computer. To do it properly, you must place the mp3s in the folder that says My_Music which is located in the micro SD card. That folder is created once the micro SD card is first inserted into the phone.
I hope that helps.
Jan 03, 2010 | Samsung BlackJack II Smartphone
I inserted my micro sd but I can't see it
try to look for the SD "Storage Card" under "My Device"
If you entered to the File Explorer, go "up" from the "My Documents" folder.
iPhone Repair
Dec 27, 2009 | HTC S620 Smartphone
2 Answers do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
Recently bought a micro sd card for my black jack and when I insert it and open storage card folder on phone it says not found
ok first the micro sd card cannot exceed 4gb or the phone will not recognize it, if that is not the problem then you will have to format the card on your pc go to computer and right click on the card and select format then place back in phone. hope this information was helpful:)
Nov 03, 2009 | Samsung BlackJack II Smartphone
I hav htc t-mobile wing i have inserted micro sd card in the sd card slot of it but in the storage card memory it says "total storage card memory : not installed" i have also tried other cards (witch...
Take out the SD card.Turn off the phone and take out the battery. Now insert the new SD card and then insert the battery. Turn it on and then new card should get detected.
Aug 08, 2009 | T-Mobile Wing™ Smartphone
Help finding my micro sd card on my phone.
Be sure to have the card properly inserted into the phone. Next go into the start menu on your phone. After that go into tools in tools you will see a program named File Explorer. From the file explorer you can see all the files on your phone. From there you should see Storage Card. Open the storage card file and there it is.
Mar 10, 2009 | AT&T 8925 Tilt Smartphone
Stuck Mini SD Card in Blackberry BOLD, 9000
same thing just happened to me... i had to use a small pin to *gently* pry the card out.. i am now reluctant to put it back in but atleast its out...
i have a feeling it might have been inserted incorrectly but as the sales guy did it at o2 im not sure...
good luck
Dec 12, 2008 | AT&T Blackberry Curve 8300 Smartphone
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
Mar 19, 2008 | RIM BlackBerry Pearl 8100
Sd card dilemma
Stylus at the top.
CAMERA at the bottom.
Holder Storage Card Slot Cover in the middle. Remove the back cover and then pry open the slot cover to install the micro SD card for storing data.
"Don't take life too seriously, you won't get out alive."
Mar 03, 2008 | Sony Ericsson K810i Blue Smartphone
T-Mobile Wing™ Smartphone Logo
181 people viewed this question
Top T-Mobile PDAs Experts
Martin Murray
Are you a T-Mobile PDA Expert? Answer questions, earn points and help others
