Question about Jensen LXA300 Car Audio Amplifier
Trying to find out if my old amp is shot. i hooked everything up but the input from the sterio. and no lights come on. i check for power and there is 12 volts going to the amp and a good ground. do i need to have an input hooked up in order for the amp to work. i would rather know before i run another set of wires to the amp
  • 1 more comment
  • Rob Dez Jul 30, 2009
    i hooked up an input into the low signal input with the sterio running still nothing. checked the speaker box it's good. fuse is godd but the amp was sitting for about 8 years so i don't know what else to try i think it must be corroded
    that is something i didn't try. there is a screw between the hot and grnd that says RMT and it wasn't hooked to anything. as far as the power and grnd i had used a volt meter to make sure there was power at the amp. someone else on here at live chat had told me the amp will only come on if there is a signal going into it on the low input. i'm going to try and jump the RMT to the hot and see what i get. that makes a lot more sense thank you.
  • Rob Dez Aug 02, 2009
    i had added a switch beside the seat to the main hot running from the battery to the amp. After talking to you i ran a wire from the fuse box to the amp and it turns on/off with the key so everything works great. the amp is only running a big speaker box so the the main power switch is at least useful if i dont want all the base in town. thanks for all the help
    Rob
    Problem Solver:
  • 6 Answers
Yes
Posted on Jul 30, 2009
  • kennyls98751 Jul 30, 2009
    Is your ground on a Painted surface if so this can also cause a problem. Im sorry i wasnt aware that you had no lights. the remote wire has to be istalled as well. it should be a blue wire or a screw that says remote. it is what turns the amp on and off with the the position of the key if you just want to test it and already have a 12 volt and a good groun jumper the 12 volt to the remote or SWITCH on the amp. if you already have done this and ground is good and your sure your getting power it may be a fuse in the amp. if you have checked all this and still no lights Its Probably the amp.
  • kennyls98751 Aug 01, 2009
    No Problem, that Remote side has to have a 12v power it can be small gauge it only has to carry a signat to turn on the amp when the signal is lost the amp is switched off. Run this to a wire in your fuse box that comes off with the key so you dont drain your battery or you can install a switch to a constatly hot wire. Glad I could help.
Hook a wire from your power antenna or your remote wire( not from both! one or the other!) on your deck(radio) to the RMT connection on your amp. all that connector is for is to give the amp 12volts to "turn it on". with out that wire your amp will not come on. i advise using the wire off of your deck simply because it is a regulated power source. the one from your battery lead WILL fluctuate and most probably do damage to the amp.
Posted on Jan 20, 2011
I NEED YO KNOW HOW TO HOOK UP A MICRA FARAD 500K
When I used to do this, I would run the power wire from the battery to the Capacitor and then run power wires to said amp. For the crossover, just run an 16 or 18ga wire to one of the Amps power input instead of running it to the cap if its easier. Not sure what Crossover you have, So check the manual for the correct wire size!
Nov 21, 2011 | Audio Players & Recorders
The amplifier power ligh comes on but the sub woofers wont play what could be the problem. I hooked up a different amp and it worked just fine.
Even tho the power light is on doesnt exactly mean that the amp is sending signal to the speaker wires.... sense everything else is working make sure to check your fuses on the amp and also check to make sure that the amp is "receiving" an input from the RCAs
Feb 25, 2011 | Car Audio & Video
When i turn the amp on the light turn red and it goes off no green light g the amp was getting hot shotting down
when you hooked the amp up did you make sure your speakers were all in-phase positive to postive / etc.. a common issue with hi-power equiptment is grounding whatever input power supply gauge wire was used the ground has to be equalized, also if youre drawing too much on the amp (too much speaker/not enough amp ) this problem will continue till the amp cooks, check all phase, and if youre mono-bridging make sure this amp can be mono-bridgeable that would also send an amp into protection mode because its recognized as a short to positive-good luck
Jan 17, 2010 | SPL Audio Phantom DK2-1000 Car Amp
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
try hooking the remote wire to a rem wire on the back of stereo. post and let me know results
May 30, 2009 | Rockford Fosgate Punch 401S Car Audio...
The radio wont turn off when i turn the key
You could be hooking up the main power to a full time hot rather than the radio circuit. Use a test light to find the switchable hot and hook up your power wire to it, then then memory for the radio goes to the full time hot.
Apr 14, 2009 | 1991 Chevrolet S-10 Blazer
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
RCA Pre-Out Making Producing a Mumming and a Popping Sound.
the speakers hook to speaker wires not to any thing else no power no negative poles do you have a remote shut off switch connected to amp this would be important to cut off amp
when cut off amp if you still here the humming this can be an indicator of low power being produced by alternator alternators produce 14 anything below 12 would mean replacement of alternator
if alternator fine then you need to find new ground for amp and make sure you have a good ground for sterio this can be checked with a test light
to check a ground all you do is hook gator clip to power then touch test light end to ground on radio end light comes on got a good ground (make sure not to touch any other sterio wires just the ground wire while connected to power to check grounds)
if pulsing in test light on the ground means you have a bad ground
just disconnect move to better ground
check the amp ground the same way as decribed above
May 09, 2008 | Pioneer DEH-P3900MP CD Player
I have a philips cd player model# FW-C70/37, that has power going to it but has no sound coming from any of the speakers, nor will the cd changer open.
cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
May 07, 2008 | Audio Players & Recorders
Low level noise causing sub flutter
the ground may not be coming from your stereo it should be coming from a loose wire under the hood. Do u have the factory radio? that might be it if u do
Sep 09, 2007 | Car Audio & Video
Jensen LXA300 Car Audio Amplifier Logo
162 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
