Question about Echo Garden
Echo trimmer with bump feed is not feeding
I have an Echo trimmer that is not feeding line.
    President:
  • 1,273 Answers
Sadly, they do wear out..... but sometimes they're just stuck. The line can refuse to feed if the line is caught on itself in the spool winding, or if the head is bad. Try this: remove the spool and clean it pretty good. Check that the line isn't caught on itself in the spool. Sometimes it just locks itself in between wraps, and you have to pull it out of the groove to get it to continue to feed. Give the inside of the spool a liberal dose of graphite powder. Put the spool back on with line. Bump it against the ground as much as you feel necessary to further distribute the graphite. Now, push the spool in as if to feed line, and pull on the line. It should feed a bit and stop. If it does, you're good to go. If not, replace the spool.
Best regards. Hope this was helpful to you, --W/D-- Please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
Echo SRM225 line trimmer continually feeds line
If the line feeds with out bumping it nay be the line gas been put on the wrong way
Apr 30, 2017 | Echo Garden
How do you pull out more line on toro 910 home trimmer
The feed bump located on the bottom of the unit is the portion of the head that you tap on the ground to feed more trimmer line as you are trimming!
Mar 18, 2017 | Toro Garden
Lost owners manual, how do I advance the string
Hi don watts46...
Bump the rotating end of the trimmer on the ground while it is running and it will automatically feed the line out, the more you bump the more line feeds out.
Please take time to rate me
Aug 20, 2011 | Troy Garden
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Sparepart for bump feed
Try googling.... www.homelite.com....enter your model number and they will have the illustrated parts page for you to find the correct part you need and it's price...hope this helps.
Jul 04, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Garden Logo
727 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
