Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic TH-37PX60U won't turn on. We had a fuse
Panasonic TH-37PX60U won't turn on. We had a fuse blow this morning. I reset it and now everything seems to work except for the TV which will not turn on. Any ideas?
Will not turn on after power outage. Is there a reset button?
No, no reset button. Some sircuit of your TV was victim of poser surge, typical to power outaget events. Flat TVs are paerticularly sensible to power issues.
You'll have to take it to repair
To protect your TV buy a surge protector
Top Rated in Surge Protectors
Jun 19, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Is there a fuse for the power
Yes there is---requires back cover be safely removed: follow the power cord which will go to it.
Apr 28, 2012 | Panasonic TH-37PX60U 37 in. Plasma HDTV
We have a Panasonic TV - Model TH-37PX60U (purchased 08/2006) that makes a "chirping" type noise periodically - sort of comes and goes. Any idea what this might be? Thanks, Mike G Pinellas Park,...
Sometimes that "chirping" is caused by loose windings on various transformers. You can usually isolate a particular transformer by pressing on it when it is "chirping" & it may stop "chirping" or the frequency my change. If that is the cause, you can A: replace the coil, B: replace the Printed Circuit Board, or C: Do nothing as it really isn't hurting anything but your nerves.
Oct 22, 2011 | Panasonic TH-37PX60U 37 in. Plasma HDTV
I have a panasonic TH-C42HD18. Last night a fuse in my fuse box flipped so I lost power to the tv. I reset the fuse (in the fuse box) but now My tv will not turn on. Everything else plugged in to that...
If you have no power light on TV ,then you must have a blowed Fuse on the power supply board.
Check Fuse and check board for Bad Capacitors they will be vented or swollen on Top.
1000uf 16v 2200uf 10v 3300uf 10v.
Jun 02, 2011 | Panasonic TH-C42HD18 42 in. Plasma TV
Wont turn on
replace the power supply.
replace the power transistor near the the flyback.
check also the fuse if is good
Jun 20, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Picture and Sound flash from 'on' to a black screen
Hi, The problem lies within the unit. You have a hardware failure within the board. The power supply board needs to be repaired or replaced. If you are a handy person, you can easily swap the power supply board.. If not, bring it you to local reapir shop, they will find the parts and replace it for you. I wish I had a better solution like an easy fix for you. Sorry, but on hardware failure, there is no easy fix. Thanks, Mike
Nov 02, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Tv will not turn on
Possible power supply panel faulty.
Feb 09, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
765 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
