Question about Goldstar KG6000R Window Air Conditioner
Can you add freon? - Goldstar KG6000R Window Air Conditioner
  • Goldstar Master
  • 1,144 Answers
Most of the time, these types of units are sealed. Meaning, there are no service valves or ports to allow access to the system for charging. An experienced tech could probably do it. I have. If you have to pay someone, it's probably not worth it.
Most of the time, window unit just need a good cleaning. It's pretty rare that freon needs to be added. I've done 1 . All the others just needed a real good bath. Be sure to let it dry for at least a day before putting it back into service.
Posted on Jul 30, 2009
How do a add Freon into a 745Li BMW?
buy can with hose adapter and hook it up according to instructions to the low side port the following link shows how to add freon to different vehicles your vehicle is not their but the explanation and how to are the same for adding freon
How To Add Freon To Auto Yahoo Video Search Results
Aug 17, 2016 | Cars & Trucks
Need to add 'freon' to my samsung window unit.
Hello, in order to add freon to a window unit you must add a piercing valve to then low side of the system. The valve mounts to the suction line and allows you to connect your gauges and add freon. Here is a link to where you can purchase piering valves. http://www.hvacr-tools.com/mm5/merchant.mvc?Screen=PROD&Store_Code=HVACR&Product_Code=BPV31&Category_Code=VALVES
May 30, 2011 | Samsung Heating & Cooling
My Amanda wall unit keeps freezing up. Cleaned filter and coils, please advise. Thanks, Gilbert
If a AC unit starts to freeze up, then that is a sure sign that it is low on freon. A wall unit is harder to add freon to since those units generally do not have Shrader valves to purge or add freon. It is sort of like your refridgerator in that the freon is sealed in the factory and to add , a technician has to cut the evaporator tube and add a valve, then add freon, pinch the tube off and seal it once the correct pressure is adjusted.
I would say that somehow your unit has developed a leak, and will get worse.
see:http://real-estate-agents.com/tips/hvac/maintain-air-conditioner/
Jan 23, 2011 | Amana PTC123B35AE Air Conditioner
How do i add freon to a 1993 caprice classic
find the low side service fitting this is where you add freon. start the car, turn on the ac to max and add freon. is your system r12 or r134a?
Jul 26, 2010 | 1993 Chevrolet Caprice
How to add refrigerants? To a 2000 buick lesabre.My car is blowing hot air it went from cool to hot. and now it just hot air coming out.
look for the fitting that is the smaller of the two and is attached to the line that is the larger of the two, this is the "low" fill side, add 2 cans of r134a freon each can is one pound the system empty holds 2 3/4 pounds of freon thats 2 3/4 cans.
I would buy 1 can of leak detector/freon combo and one can of dye/freon combo, if it takes more add a small amount of a third can that has an oil mixture in with the freon that would complete your systems needs the cheapest and fastest way possible.
If you want it done to the book then you need to have a certified A/C man vacumn pump down the system, replace the reciever drier, add freon and oil to fill the system and then check for leaks.
Happy Motoring!!
Jul 14, 2010 | 2000 Buick LeSabre
Ac add freon
how to add ac freone to 2006 chevy equinox
May 19, 2010 | 2005 Chevrolet Equinox
How to add freon?leak fixed but can find the nipple to add freon.
there is no nipple to add freon, but there is a service valve.. this is a sealed system, only someone with their lic should be adding refrigerant
Oct 02, 2009 | Refrigerators
Low freon and low pressure cutout open preventing clutch from coming on
Before you add Freon, you should check the leaking first, if the Freon is too low, sometimes cause this kind problems. use color Freon test it and tight the leaking area and then add Freon, you can not do it yourself because the law say.
Jul 27, 2008 | Chevrolet Lumina Cars & Trucks
Goldstar KG6000R Window Air Conditioner Logo
329 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
