Question about Hayward H Series Millivolt 250,000 Btu Pool Heater H2501
Hayward mod h1501 light pilot it stays lit turn temp up and it run,s but when we turn it down and shut it off the pilot go,s out and we have to lite it every time we use it,s out. a new gas valve in will still do it. put a new thermal couple in will still do it. put a new blow back sencer in will still do it.clean all connection,s will still do it. do you know what is wrong. HELP HELP HELP. JIM HARLAN
    President:
  • Hayward Master
  • 1,378 Answers
Check the burner tube closest to the pilot side of the burner tray. Is it burning a nice blue like all the rest? If it is not, clean out the jet on the manifold in front of the tube.
If it is ok, can you get a millivolt reading off the generator (thermocouple)? If so, get the reading with just the pilot on it, then with the burner load. Finally, watch that reading as the burners run for a while to be sure it climbs.
The only other thing I can think of would be to get manometer readings to verify gas pressures before and after the valve.
Posted on Jul 30, 2009
Per landlord, need to light pilot
You would smell the gas, so you're probably ok. Lighting the pilot is not too tough, first you have to get the cover off the furnace. Inside you will see pipes and parts. Hopefully on the cover, inside or out, or somewhere inside the furnace will be instructions.
If not, find a knob that has 'pilot', 'off' and 'run' or something like that. It will probably be in 'run'.
Usually, you have to push the knob down and turn it to get it to the 'pilot' spot. When you do, have something to lite the pilot, which will be inside the furnace more, near the burner. The burner looks like a gas stove or oven burner. The pilot place will be at the end of a small tube.
With the button held down, wave something burning around the burner area. especially at what may be the pilot. The pilot doesn't put out much gas, so don't worry about things blowing up.
Once the pilot has lit, hold the button down for a while, at least a minute. Then you should be able to release the button and the pilot should stay on. If it doesn't, you need a serviceman to come. Let the landlord know the pilot would not stay lit.
If the pilot stays lit, move the knob to 'run' or such, and the furnace should lite, if the thermostat is set higher than room temp. If it has been off, and the room is cool, it should lite.
If the furnace doesn't come on, let the landlord know.
Most landlords have service people for this, it was my job for a long time. Lighting pilots was a common chore for me. If you can, have the landlord send one out to show you how to do it.
As you see, it's not all tough, but it's not all easy, either.
Nov 29, 2013 | Heating & Cooling
My gas wall mount heater works a while then shuts down. why?
When it is running check the flame. It's triggering a rollout switch.
Feb 27, 2013 | Heating & Cooling
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
My living room gas heater will not stayb lit
Try replacing the thermo coupler.There should be a little bulb shaped part(like a pencil eraser) that the pilot light heats up .The other end screw into the gas valve.If this is going bad or has gone bad the pilot light will not stay lit.Most of these are under$10.Well good luck and try to stay warm.
Feb 02, 2010 | Grilling
Gsw heater pilot stays lit, but when the main
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Oct 03, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
My Hayward pool 350000 heater will light and stay lit and heat the pool for a while, but will just shut off including the pilot light. When I re-light it it works for a while again and then shuts off...
Sounds like the pilot assy needs to be replaced. It has 2 functions one is to light the main burner but also to let the system know that the burner is lit. If it thinks the burners are not lit it turns the gas off
Jun 23, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
Jun 19, 2009 | Hayward H Series Millivolt 250,000 Btu...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Millivolt 250,000 Btu Pool Heater  H2501 Logo
257 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
