SOURCE: P0420 and P0430
The AF sensors are uupstream and the O2 down stream. The car' s computer tests them and it is saying your cats are bad. If you have a scan tool you could look at the data and see what the sensors are seeing. The Af sensors are the ones that control the fuel ratio in the car while the O2's just watch. AF's would be the one to change but there is no garuatee that the codes won't come back.
SOURCE: i have a 2000 kia sephia and need to know what the
This is a catalytic converter code. Below threshold. Replace converter.
SOURCE: I got Engine codes PO135 and PO155.
those are the sensors before the cat
Testimonial: "Thank you ajrinthepeg."
SOURCE: location of oxygen sensor bank 2 sensor 2 for gmc sierra 1500 v8
Bank 2 is the bank that is farther back than the other when looking at eng from the front you will see that one cyl head is farther forward (closer to radiator than the other. this is #1 Bank) #2 is the opposite and sensor #2 is the one after the Catyliac Convertor towards the muffler. #1 sensor is between head and Cat.
SOURCE: where is downstream left o2 sensor located in 2005 kia sportage?
For oxygen sensor location diagram on kia sportage, click the link below:---http://technoanswers.blogspot.com/2012/12/o2-sensor-located-in-2005-kia-sportage.html
These will help.
Thanks.
