Question about Ruud UBHC Air Conditioner
FINDING A DIAGRAM FOR A RUUD AIR HANDLER ON LINE
I NEED TO FIND A WIRE DIAGRAM FOR THE ACHIEVER MODEL
  • 447 Answers
I dont have axcess to a wiring diagram but i am pretty familiar i know the heater wiring is crazy on these what are you having trouble with??
Posted on Nov 24, 2007
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Jan 05, 2010 | Ruud Handler Air Conditioner
How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Feb 21, 2009 | Ruud UBHC Air Conditioner
Need to find ac coils for RUUD ac in the Air Handler
follow the copper lines coming into the air handler.1 will be large and insulated and the other smaller and uninsulated.They attach to your evap coil.
Aug 18, 2008 | Ruud UBHC Air Conditioner
Ruud air handlers
Check the name plate amperage on the air handler. The air handler only has the blower motor as its main current draw. #12 wire is rated for 20 Amp service. If the amp draw by the unit supplied by the disconnect is under 15 amps it should be fine (but) once again check the name plate for ampacity rating.
May 27, 2008 | Ruud UBHC Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Sep 02, 2007 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
1,006 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
