Question about Garden
My LawnBoy mower 195 cc 4 cycle that starts fine. After about 5 minutes of grass cuting the engine starts to cycle until it dies. If I leave the mower sit for about 5 minutes, it again starts fine and runs for a few minutes until repeating the process. I have replaced the spark plug and the air filter. There is plenty of oil in the engine. What could be causing this?
    President:
  • 1,273 Answers
It sounds as though it is starved for fuel. Check the pinhole vent in the fuel filler cap. if it is plugged, the engine will still draw fuel, until a vacuum is pulled on the tank, resulting in no fuel. If this doesn't fix you. check for adequate fuel at the carb, and wirk either forward or backwards from that point, depending on what you find. I'm betting on the vent!
Try it; it may be just the thing!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
Weedeater riding mower with briggs and statton 19 cc 875 series engine won't turn over like its locked up. was running fine shut it off for 5 min and started back up and as soon as I went to engage the...
Do the basics, check the battery voltage first. If there is not enough battery voltage present when you try to engage the blades it will certainly die and may not start until the battery is either charged or replaced. There are other items to check but do this first.
Aug 04, 2014 | Garden
What is wrong with my push mower?
Sounds like something relating to the engine is overheating and the heat sensor switches off the machine.
Jun 18, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Lawnboy model 10640 walk-behind mower pull cord will not retract. I've removed the plastic engine covering, removed the top bolts of the gas tank and rotated the tank back. With the flywheel cover being...
I have the exact same problem. I read on another site that the blowout hole in the back of the mower where the grass goes into the catcher must be cleared of any grass or dirt. I don't use the grass catcher and indeed the hole was full of dirt and grass. I cleared out what I could with my hands and a screwdriver, and magically somehow the cord retracted about a foot. Enough to start the mower with. It still doesn't retract all the way, but it was an improvement. I may have worn out the spring pulling and tugging on it trying to get it to retract, but ok for now.
Please share if you find a more permanent solution. Mower is barely a year old.
Apr 21, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Over heating minutes after starting
Take the engine cover off and check to see if there is dried grass,leaves,etc packed inbetween the cooling fins on the engine. Some animal may have decided to make a home there.
May 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Runs but cuts out when transmission is engaged
Check the deadman switch on the seat, I had the same problem with my John Deere and that's what it was.
Apr 22, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
My brand new Briggs and Stratton Lawnboy won't start!!!
if you play with it u will void the warrantee. call the dealer u got it from
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
What is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Mar 29, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
1,053 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
