Question about Clothing
What is the difference between a molded, contour, push up, and padded bra?
  • 662 Answers
Hello, Lata -
molded bra - has cups made of a synthetic material and shaped by a machine using a heating process; the cups of a molded bra hold their shape when not worn
contour bra - also has shaped cups like molded bras but have more structure; the shaped cups are lined or even padded and may have underwires; the cups of a contour bra hold their shape when not worn
push up bra - makes the wearer look as if she has more cleavage than she has naturally; they tend to have under wiring and padding on the cup sides or in the lower sections of the cups
padded bra - has added material inside the cups to help make the wearer have a larger bust line and enhance cleavage
See information on these web sites:
https://www.barenecessities.com/article.aspx?articlename=BraGlossary
and
https://www.liveabout.com/types-of-molded-bras-and-how-to-wear-them-4019418
Posted on Dec 20, 2017
2 Suggested Answers
mccluskey1
  • 8204 Answers
SOURCE: Would girls with big bra cup sizes wear plunge push up bras with padding?
my wife said try it and see what it looks like on you,it did not look right when my wife tried it,so unless you try it you wont know.
Posted on Oct 12, 2017
Oct 12, 2017 | Washing Machines
Can the plastic heat or sound barrier under carpet pad set off a bad smell as it gets old.it's all cracked in pieces
In a word, yes. But it usually is moisture that gets into the cracks and carpet pad and mold starts to grow. Sporicidin Enzymatic Mold Cleaner is the best I've found for mold cleaner.
Feb 01, 2015 | Cars & Trucks
How to measure your bra size
Access: http://www.google.ca and enter "how to measure bra size" and read the web-pages suggested by Google.
May 19, 2014 | Baby Care
Can a nursing bra help prevent milk from leaking on clothes or are ****** pads needed?
Usually nursing bras are enough to protect the clothes from milk leakage. However most women prefer keeping their nursing bras cleaner by wearing breast pads.
Jul 03, 2013 | Baby Care
Trying to get the plastic pieces of the rear bumper of a 2004 ford f250
Remove the rear bumper and push clips out from the inside of the bumper. Careful these tabs are plastic molded to the pad.
Nov 04, 2009 | Ford F-250 Cars & Trucks
95 ford contour
look to see if fluid level is at full running in park and warm, if it is then check for vachum leak.
Aug 26, 2009 | 1995 Ford Contour
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
When i apply my brakes on my 98 contour the front end shakes
Sounds like you have bad brake pads or rotors ..if you are not mechanical take them in somewhere ......if the brake pads are left too long the metal will wear away the rotors and then it all needs to be replaced....hopefully just the pads need replacing but it sounds like if it is shaking that bad rotors are gone too. usually the pads will make a sqeaking sound when the get to worn so you know that they need replacing.
Jan 12, 2009 | 1998 Ford Contour
Factory alarm
the only way to reset an alarm is to disconnect the battery cables.
there is no such thing as an alarm reset switch.
My suggestion would be to go to autozone, they sell replacement key pads.
Aug 04, 2008 | 1998 Ford Contour
1998 Ford Contour seat belts
ask to have a record for recalls on your car recalls are repairs
than dealer have to get done to cars free of charge
the way the recalls are set by goverment agencies is by complaints from customers to the higway safety administration
or also to the customer afair i thing so
when they receive too many complaints with same problems then they will force the dealer to fix many cars free of charge,
i hope and this help
but make sure to ask the dealer for recalls of your car. and ask for a print out.
May 26, 2008 | 1998 Ford Contour
Clothing Logo
80 people viewed this question
Top Clothing Experts
Bill Boyd
Da Doc
ray gallant
Are you a Clothing Expert? Answer questions, earn points and help others
