Question about Kenmore 16973 Stainless Steel Dishwasher
Dishwasher makes a humming sound, but does not flow water to jets
Problem Statement - Dishwasher makes a humming sound, but does not flow water through the wash jets.
1. Dishwasher control panel functions - Entire dishwasher cycle will run.
2. Dishwasher fills - float works.
3. Dishwasher empties and fills during cycles.
4. Dishwasher heats at end.
5. Dishes are dry and soap remains in tray - Hence - my original problem statement description.
Investigations Round 1:
1 a. I disassembled and reassembled the interior wash assembly to check for damage or debris. None found. Screens are in good shape.
1b. It was hot and I needed to get the manuals - I stopped. Washed dishes by hand for 3 weeks (Yuck) - tonight new investigations:
Investigations Round 2:
2.a Removed dishwasher from counter enclosure - Uh oh it appears that I have a mouse that likes fried chicken bones - might be a country mouse.... note to self, get a trap and a bone for it.
2b. After some study, I think I have a good idea of the things underneath.
2c. disconnected the drainage line - no debris or plastic - felt into the pump area... no obvious damage, can spin whatever you call a pump's little blades on spindle thingy.
2d. Took off the motor and with it the white assembly embedded into it. Removed (pump well?) screen. No debris.
2e. The little transmission like gear at bottom of well is not damaged, appears to turn fine without any resistance. (maybe it shouldn't?).
2f. Looking at motor assembly - do not see damage that is obvious - but I'm clueless - doesn't smell burnt.
2g. Looking at the white pump wheel assembly thing... it turns, a little resistance... not sure if I felt a little grinding at the beginning - may have but wasn't sure what it should feel like. Tried to remove this part... couldn't and didn't want to force it.
I stopped here - re-assembled everything - gave the motor a light "technical tap" with my hammer. - re-installed in counter. Tested... still same problem (so much for the tap).
My questions / thoughts - is it likely that the motor is just broken? If so, is the white pump assembly thing embedded within the motor a removable thing? or does all come together? - Maybe white pump assembly wheel shouldn't spin freely... not sure about that.
How can I fix this without buying parts that are the wrong ones.
Hopefully one of you very smart guys can help me out. If so, it will be very very much appreciated.
Sincerely,
Michelle
  • 98 Answers
SOURCE: 4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Posted on Jul 26, 2009
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Posted on Sep 04, 2009
bobicehouse
  • 1524 Answers
SOURCE: Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
Posted on May 19, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Kenmore Elite
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have washed and rewashed
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
l'l
Posted on Mar 04, 2011
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
I bougt a kenmore 18" dishwasher, the dishwasher
Sounds like the water is either off or a flood safe hose is being used. The valve is energized and water is not flowing in, that is what the humming noise is.
Appliance & Refrigerator Repair
Mar 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher does not fill with water. It hums as if it is trying to work.
If there is water in your inlet and on switch of program there is water coming into the washer, it is possible that the Hum you are hearing is the inlet valve/pressure pump that is not activating.
It might be getting warm if humming for a while and you can check this out. Remove the unit and checkit out onthe table by applying voltage for the water flow or pumping. Dirt accumulation can make it stuck and if not replace .
Sep 17, 2010 | KitchenAid KUDS50SVSS Builtin Dishwasher
Water not flowing
Be sure that the water supply valve is turned on. If it is and the water line to the dishwasher is not obstructed, the water inlet valve on the dishwasher is bad.
Jul 20, 2010 | Westinghouse 24 in. MDP531 RF...
No water
Check the incoming water to the dishwasher. If the filter is clogged clean it and re fix. Strainer is located on the machine inlet junction where the hose is fitted.
The humming sound is due to motor running without water. When you rectify the inlet flow fault, pour additional water manually into the wash chamber and run the cycle. This to remove trapped air in the pump due to dry run.
May 28, 2010 | Caloric 24 in. CDU300C Built-in Dishwasher
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Dishwasher motor makes like a grinding noise on start up
Hi. This grinding or hum can be associated with internal electric motor failure. the grinding and humming sounds are warning signs that will ultimately, lead to total failure.The actual term we in the industry use is A.C. hum. This will occur when the internal electric motor windings begin to break apart from the center housing inside the motor casing. this will disrupt the current flow, causing over heating. the grinding is because of the alignment that has been disturbed as well. The solution is to prepare for the replacement of the electrical motor or, you can repair it.
please rate and have a great day.
Mar 21, 2009 | Dishwashers
Dishwasher not moving past sensing cycle
humming noise sounds like a solenoid is not snapping in, this is not something that the average or even above average homeowner can fix. Solenoids go bad, they are a moving part that are activated by electricity, can be dangerous to mess with as water and electricity don't mix. Get a repairman or get a new one.
Apr 28, 2017 | Kenmore 15952 Dishwasher
My dishwasher is making a humming sound and does not rinse?
A humming sound can be a failing wash motor (that drives the water pump) or it can be as simple as a blockage in the the pump area beneath the lower spray arm, under the filter.
Remove the spray arm and the filter top (screws will need to be removed)
Use a flashlight and inspect all over the sump area for debris that is blocking/jamming the impeller area. Reasemble and test with a short cycle.
If the dishwasher continues to make the same humming, it is time to replace the wash pump.
Good Luck! Post back here if you would like more guidance.
Dec 08, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Problem with Miel dishwasher: no water
if the valve is humming and the tap is on it should fill.is there a plv fitted to the tap somtimes they fail.i had one today on an asko for not filling.remove the hose from the dishwasher and turn the hose on into a bucket to see if water comes through.the valve could still be faulty.hope this helps.
Mar 19, 2008 | Dishwashers
Kenmore 16973 Stainless Steel Dishwasher Logo
51 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
