Question about GE Profile Harmony DPGT750EC Electric Dryer
How do you remove the back plate of a GE profile Harmony. I have the screws out, the top off. Does the back plate slide up? Do the sides have to come off with the back? Or what?Please. Thanks
  • 33 Answers
The back plate does not come off.
to get to the motors, belt, sensors...
remove the screws to the inner top cover(under outer cover) and the plastic strips- slide strips front or back to remove.
remove the screws to the front panel- 2 top front, 4 inside door.
as you pull the front off, unhook the light and the door switch
remove the scres to the front drum plate.
reach under drum and unhook belt-take note how it goes around motor and tensioner.
lift drum out and observe everything else.
Posted on Aug 02, 2009
How do you take off the back panel to get to the inside?
you cant remove the rear panel the sides and back are all one piece,you remove the control panel screws in the back,then the control panel,then the top panel cover comes off,the front then comes off,remove the drum belt and drum and you can get to the inside rear wall from here
Jul 17, 2011 | GE Profile Harmony DPGT750EC Electric...
How do i remove the lid on a ge profile harmony washer?
Use a putty knife to remove the front panel first/
The putty knife will insert between thr top of the lid and the front panel about 2 inches in from each side.
The panel will pull forward then up to remove it.
Then remove the screws holding the lid down.
You may have to open the control console to remove the lid.
Apr 03, 2011 | GE Profile WPRE6100G Top Load Washer
How do you remove the washer door
Thanks very much, but my husband found a way to remove the lid on the washing machine. There are 3 screws on each side of the lid that have to be unscrewed in order to remove the lid.
Jan 13, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Replacing felt around drum - model dpsr610eg0wt
On the DPSR610EGWT if you open the dryer door and look at the top of that opening There are two small phillips screws that hold down the top of the dryer. Unscrew those, lift the top and then slide it to the left to remove the top. Next, near the top of the seams between the front and side panels is a screw. Unscrew the small screw and the front will lift off. Be careful because the drum is supported by the front and there are also wires connected on the left. Hope this helps!
Aug 23, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
How to get the front panel off GE Profile Harmony
Here's a simple overview of what you have to do:
You actually don't remove the back sir, but that's okay, that's a common misconception for this model dryer. The proper way to disassemble this particular dryer is you start with the top. You have to start with the removal of the control panel, then the top of the dryer. What I would consider the top cover. Then you'll have to remove two plastic brackets. Then you have to remove the front. There's two aluminum brackets in each corner, remove those. Open the door and there'll be two more screws to remove on each side. You have to lift the front just a little and then pull towards you. I forgot to mention, before that part, you'll need to ensure you are disconnecting the electrical wiring. There's almost no chance of connecting the wrong ones even if you forget. GE made this part novice proof. Once you get the front removed, you'll see the lint/trap. There's a couple of screws on either side of the aluminum housing. Not much to it. Let me know if there's anything I can clarify further. Have fun!
Mar 31, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Jan 03, 2009 | GE WPGT9360EPL Top Load Washer
Ge profile dryer
look inside the dryer corners where the back panel is. there may be some bolts visible from INSIDE the dryer corners.
Dec 04, 2007 | GE Profile Harmony DPGT750EC Electric...
Close the Lid problem on GE Profile Harmony
Kevin, the switch is magnetic operation. You will have to remove the top to get at it. Do this by removing the back panel. Inside the panel on the left side will be 4 harnesses. Disconnect them. Remove the pressure switch hose from the tub. Remove the ground wire. In back on each side of the top panel there will be 2 phillip screws, remove them. Now lift the top from behind and slide foward. The whole top comes off. The lid switch will be on the underside just in front of the dispensor. You can test the sensor by using a magnet. Just open the lid and place a magnet just in front of the dispensor on the left side. The washer should work with the lid up. Catriver
Nov 30, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony DPGT750EC Electric Dryer Logo
213 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
