Question about JVC RX-6008V Receiver
Overload comes on after start up - JVC RX-6008V Receiver
    Sergeant:
    Champion:
  • 231 Answers
Disconnect all speakers to see if 'overload' goes away.if it goes away then you might have a bad speaker.If OVERLOAD is still there with no speakers connected .Then audio output circuit needs repair in unit..
Posted on Jul 30, 2009
When the compressor tries to come on, why does it click and hum, then clicks off?
Two causes for that situation. The compressor has a start relay and a overload mounted on the 3 prongs. When the relay/overload is bad, compressor will kick on, hum, then a click sound. The click is the overload. Or, the compressor is drawing too much power and the compressor is bad. 90% of time it's the relay/overload but you need to check and make sure fan is running by compressor and coils underneath are not clogged up. Poor air flow around compressor can cause overload to go bad.
Aug 19, 2015 | Refrigerators
Why why why2003 cayenne turbo battery overload light comes on
Check the second battery in the back, under the subwoofer.
Sep 04, 2014 | 2004 Porsche Cayenne
Overload comes up on receiver when sound starts what causes this?
too many cables from outlet , use dedicated power source 12 amp
Aug 30, 2014 | Audio Players & Recorders
WEA18061AU When turning on start light comes on
Could be overloaded. Use less clothes to start. Load sensing will not let an overloaded washer to continue.
Oct 16, 2013 | Bosch Washing Machines
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
A clicking noise (like from a clicker) coming from underneath or at the bottom of the refrigerator, Model GD5NVAXSA. What might it be?
normally this is a bad overload relay and start capcitor.the compressor my be bad and drawing to much voltage when trying to start you can replace the overload relay and start capacitor before changeing the compressor
Sep 21, 2010 | Whirlpool Refrigerators
Every 3-4 minutes the a very loud buzzing sound occurs for ~20 seconds. It sounds like it is coming from the compressor area. The fridge and freezer are both working well.
It sounds like the starting components on your compressor are bad. the buzzing is your compressor trying to start and then shutting down on its overload. You will need to replace your starting components on the side of the compressor (start relay and overload) which will usually come in a kit together. Good luck _MJ_
Apr 23, 2010 | Maytag MZD2766GES Side by Side...
Bad overload relay
The compressor is usually fitted with a thermal overlload switch. It is usually secured to the compressor with some sort of spring mount so it maintains physical contact
The parts guy was probably talking about a hard start kit. They typically are a universal fit, and come with instructions. Be sure to check the electrical supply to the outlet for the fridge. Excessive voltage drop when it tries to start will cause such problems, and will eventually cause damage to the compressor.
Dec 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Buzzing compressor
heres a part number for the overload relay assy 5304468029.. its mounted on the side of compressor. its a tricky one, usually my experience has been the noise comes from a bad compressor( which you should have 5 year full warr from manufacture). sometimes the overload relay does go bad preventing compressor from starting,the n ew compressor will come with a new overload relay
Nov 19, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
JVC RX-6008V Receiver Logo
438 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
