My Akai tvcd combination set is locked how do I unlock it.
I have a small Akai tvcd combination set that has been inadvertantly ''locked''. How do I unlock the set?
  • 269 Answers
Try to press the display button on the remote for 5 secs. until the lock disappear then turn it off and unplug it.
Posted on Aug 04, 2009
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
How to unlock key lock on akai sty0747
Usually key lock can only be set and unset using the remote!
Feb 15, 2015 | Akai Televison & Video
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
Aug 26, 2011 | Locks & Locksmithing
How do you unlock the machine? It says that it's locked.
If you are referring to the Control Lock indicator, you may have inadvertently locked the control panel. Before assuming you have a malfunction, read the following: The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
The controls have locked and I do not know how to unlock
You may have inadvertently locked the control panel. Before assuming you have a malfunction, read the following: The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does controls lock mean? And how do I unlock
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
Nov 10, 2009 | Kenmore Elite 45986 Front Load Washer
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Not tuning
videocon 20 tv asm serch fine lock help
Oct 06, 2009 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Controls are "locked" - how do I unlock them?
The following link explains how to correct a control panel lock issue on a Whirlpool2.gif Duet:
The control panel lock is actually a designed safety feature that allows you to lock the control panel to keep small children from manipulating the controls. It can be inadvertently set by leaning against the control panel buttons, or following a power outage.
If you have questions, please let me know. I hope this helps you.
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Panel Lock on Toshiba LCD 27/30WL46 Sereies -- how to Unlock?
I WOULD LIKE TO KNOW HOW COME EVERY TIME THAT I EXTINGUISH THE TV á. THE ACCENE THE MEMORY HIM AZZERA,SE POSSIBILE TO KNOW ITS MOTIVE
Oct 22, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
