Question about Garden
Flooding carburator on my toro trimmer when i try to start it in run mode it floods
  • 130 Answers
Your going have to rebuild the carb.
Posted on Jul 30, 2009
Won't start, gas out of exhaust
Sounds like its flooded : excess fuel / wet spark plug.
Empty tank / Clean and dry spark plug. test plug for spark before refitting. If strong spark refit plug / and see if fires when turn engine over.
If it does then refill tank with new clean fuel and attempt to start without choke to avoid flooding.
May 25, 2016 | Toro Garden
Why does my Husqvarna 122c trimmer not start?
try this hold the throttle open all the way then choke it or primer if you have one then pull stat it . it should start up this is a trick that lawm mower tech use to start badly flooded trimmers are new trimmers that have not start it gets them to start right up so they can adjust the carburator so they will run this might help you to start the new trimmer you have
May 19, 2014 | Husqvarna Garden
I have a home lite ut 21546 and i put the exact mix ration with gas and then ,when i start to run the carburator come start to expulse gas and dont run
It appears that the carburetor is "flooding" in your case. Several different things can contribute to this problem, but primarily it is because you have eithter 1. Tried to pull start it an excessive number of times with it choked 2. The carburetor is dirty and requires disassembly and cleaning.
If this continues to happen, you will need to look at the carburetor closely and inspect it. To "dry" the machine out after it becomes "flooded" you can remove the spark plug (make sure it is clean and gapped properly as this can cause a no-start issue) and pull on the starter to expel the unburnt fuel out of the engine.
Nov 10, 2010 | Homelite Mighty Lite Lawn Trimmer
My toro 51970a trimmer has been leaking gas and flooding for the past few weeks, but I could start it. Today, it is gushing gas from the back when I pull the starter string. How do i fix this?
The carburetor needs to be removed and inspected. The malfunctions possibly indicate the need for a repair kit. I've been unable to locate your exact model, but if it has the 2-Stroke engine (gas/oil mix), then you will at the very least..need a gasket and diaghragm kit installed per inspection. There is the possibility that the carburetor needs a complete rebuild and would require the complete rebuild kit. Remove the gas lines (after draining gas). Remove the carb and inspect the screws and tightness of the screws in the 2 end covers. Are the screws tight? If not tighten them up and reinstall, trying to restart the machine. Post back if needed.
Oct 26, 2010 | Toro& Electric String Trimmer
Carburator floods
rebuild carb--clean ,repair or replace float and needle valve in float bowl
Apr 19, 2010 | Toro& Electric String Trimmer
Trimmers floods its self, will not stay running
It is unusual for a trimmer to flood itself. It is common to have a lean condition diagnosed as rich.
So lets start by seeing if its lean or rich. Get unit running and apply as much throttle as possible and keep unit running then slowly close the choke. If unit starts to run better as choke is closed then it is lean. If unit dies immediately and is hard to start again it may be flooded.
4 possible reasons for flooding...
1. piece of debris in inlet needle, needle lever adjusted too high
2. adjustment screwd turned too far out
3. exhaust screen clogged
4. low compression
If unit has a stuck inlet needle it will flood while engine is off and be very difficult to start- remove fuel source and/or turn adjustment screws all the way in and pull rope until unit starts ( 4 or 5 times)
clean the carb, screws should start at 1 and 1/2 turns out on the low and 1 turn out on the high.
clean the screen.
If the unit has low compression it is not worth repairing- the cost of repair will exceed the cost of replacement.
Jan 02, 2010 | Homelite Mighty Lite Lawn Trimmer
Starting issue with 323l 2 stroke trimmer
Clean the carburator, check fuel stems making sure they're not screwed in to far or bent. Buy a new choke assembly and new fuel filter.
May 10, 2009 | Husqvarna 28cc Gas Line Trimmer
Weeda eater
try www.jackssmallengines.com
Mar 16, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
