If the eject button is not working it is possible the DVD is stuck in the unit. look closely at the door on the DVD tray you should see a small hole that you can stick a paper clip in once you straighten it out, and then push it in the small hole, that should offer a little resistance then the DVD should eject. Be sure to unplug the DVD Player before trying this.
Just next to the eject button on the actual recorder there should be a tiny pinhole. If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD. Hope this helps!
