Question about LG Refrigerators
Can someone help me pls
I have an LG refrigerator model number LFX23961 my problem is it stop getting cold and we have a tech look at it and he said we had a blockage, We have reason to believe thatsmall line from the evaporator to the dryer is blocked. The line outside diameter is 1/16 I can't find that line anywhere, Can I replace it with a 3/16 line? Will this be a problem. I appreciate it someone can answer me. Thank you so much Alina
    Champion:
  • 363 Answers
I disagree with the diagnosis. I think you problem is with the evaporator fan(Freezer/refrigerator)ciculating fan, this problem is very hard to diagnose because the fan still spins, but not fast enough to circulate chilled air thru the freezer and refrigerator. This problem I have just described is true unless the evaporator coil is not getting cold.if the evaporator coil is not getting cold then I agree with the tech. The answer is no as long as you can silver solder the splice.
Posted on Jul 31, 2009
Error code on LG model
A CO error code indicates no communication between the display and the board. Unplug the wiring harness and reinsert. Hope this helps.
Jan 22, 2014 | LG Refrigerators
Low water flow
Make sure the hose behind the fridge is not kinking up, slowing down the flow rate of water.
Nov 17, 2011 | LG LFX23961 (226 cu ft) Bottom Freezer...
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
Our refrigerator stopped working after a power outage.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 30, 2011 | LG Refrigerators
A new model from lg french door stainless steel its working for 3 days and stopped suddenly and there is power on the fridge
NOTE: This
Leo Ponder
Aug 24, 2011 | LG LFX25960ST Stainless Steel French Door...
Refrigerator stopped running with no warning. Problem is NOT with the wall outlet or the breaker switch.
NOTE: This
Leo Ponder
Aug 23, 2011 | LG Refrigerators
The Lg Refrigerator doesn't cool. Its condenser is working; air flow to bottom freezer can be felt but not freezing. Condenser keeps working so the sensor seems right too. Evaporator leaking?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 10, 2011 | LG LFX23961 (226 cu ft) Bottom Freezer...
I have an lg model tfx2965sb and it keeps freezing in the refrigerator section. I have ohmed out the damper and watched it physically function. I have replaced the main pcb, and the thermister. I have...
Have you checked the cold control for the food compartment? This has a bi-metal probe on it. When they start acting up they either make the unit run to cold or to hot. The common name in the field for that is the cold control. I was not able to cross your model number as written above so my comments may not apply to your LG unit. You mentioned that you have changed a thermistor but not where it was and in the food compartment or in the freezer section. Trying to help here.. but the model number is slowing me down a bit. If it is the right model number I will do some more digging. 1st attempts came up empty.
Thanks for using FixYa!
Kelly
Feb 21, 2010 | LG LFX25960 Bottom Freezer French Door...
Refrigerators Logo
220 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
