Question about RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry is clocking. I deleted a few applications, but I believe the memory on my phone is near full. What can I do about the clocking?
MY BLACKBERRY CLASSIC HAS FROZEN,PLS HELP
Frozen how? You can't open it ? Blackberry can do this sometimes if you drain the battery completely.. you must leave it plugged in until opens. Or, you can try a hard reset doing this:
  1. Perform a hard reset to wipe all data from the BlackBerry Classic.
  2. Open BlackBerry Link on your computer.
  3. Connect the device to your computer using the USB cable.
  4. Select your device on the left pane.
  5. Go to "Back Up & Restore" > "Factory Reset" (Windows) or "BlackBerry Link" > "Preferences" > "Reload" > "Reload" (Mac OSX).
Jan 16, 2017 | Blackberry Cell Phones
Tip
How to uninstall apps on a BlackBerry Tour
Uninstalling an application from a BlackBerry Tour is a simple process that only takes a few minutes. First, find the app's icon. (By default, this icon will be located in the Downloads folder unless you've moved it.) Move the trackball over the icon and press the BlackBerry button (the one with seven dots to the left of the trackball). From the menu, select <span style="font-style: italic;">Delete</span>.<br /><br />A confirmation window will appear asking if you're sure you want to delete the program. Select <span style="font-style: italic;">Delete</span> again. You'll see a message that says, "Deletion will occur when handheld is restarted," and you'll be prompted to reboot your BlackBerry. If you choose <span style="font-style: italic;">Yes</span>, the phone will shut off and go through the cold boot process -- just like if you'd pulled out the battery. It may take several minutes for the device to fully boot back up, but when it does, the application will be deleted.<br /><br />If you choose not to restart at that time, the application's icon will be removed from the folder, but the application itself will remain on your BlackBerry until you perform a cold boot (turn the BlackBerry off, pull out the battery, then reinstall it and turn the phone back on).<br /><br />Even after you've completed the uninstall process, the application's files will still remain stored on your BlackBerry. You can find and delete these files by navigating through the BlackBerry's file system. In your Home folder, select <span style="font-style: italic;">Media</span> and then press the BlackBerry button. Choose <span style="font-style: italic;">Explore</span>, and you'll see two options: <span style="font-style: italic;">Media Card</span> and <span style="font-style: italic;">Device Memory</span>. Select <span style="font-style: italic;">Media Card</span>, then continue down the folder tree by selecting <span style="font-style: italic;">BlackBerry</span>, then <span style="font-style: italic;">app_world</span>, then <span style="font-style: italic;">downloads</span>.<br /><br />The next folder will have a name that's a combination of letters and numbers, which is your BlackBerry's PIN. Select this folder, and you'll see a subfolder with the name of the application you just deleted. (If you have more applications installed, there will be folders with their names here as well.) Press the BlackBerry button and choose <span style="font-style: italic;">Delete</span> to get rid of the folder, which is only taking up space and isn't necessary anymore since you've already uninstalled the application. If there are other applications here that you've previously deleted, you can erase their files too to free up more space.
on Dec 22, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Why blackberry curve doesn't keep messages, only holds 20 messages and erases old ones automaticly
It's because your phone memory is too low,
you need to delete some useless apps on your phone and free up some memory, when there is enough free memory, your blackberry will be able to store up to a few thousand emails without deleting them
( I have tested this and it works)
Blackberrys are built so when memory starts getting too full, the phone automatically deletes old messages and calendar entries to fee up memory so the phone doesn't freeze.
Hope this helps
Cheers!
Andy
Feb 11, 2010 | RIM BlackBerry Pearl 8100
Text that ill delete out of phone after opened
This might happen because Media settings may contribute to low memory capacity.
Modify the Device Memory Limit settings by completing the following steps:-
1) On the BlackBerry smartphone, click Media.
2) Select a media application.
3) press the menu, and click Options.
4) Set the Device Memory Limit to the lowest setting field.
5) press the menu key, and click Save.
Oct 23, 2009 | RIM BlackBerry Pearl 8100
Black screen and red light, then tiny clock? Any
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, and a link to the Desktop Manager software - the website is at : Restore Blackberry. Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
Oct 14, 2009 | RIM BlackBerry Bold Smartphone
Blackberry Pearl 8120 - sms, email and call log being deleted
On the Status screen of the BlackBerry smartphone, the File Free field indicates low ,if the device memory is full then these things will happen on your device,so to never have this problem delete unwanted applications.To delete run desktop manager and select application loader,select the applications that are not frequently used and remove them.Also keep the messages for a month or two because these mails will be there in your mail box.
Jul 20, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Blackberry Pearl: memory issues?
I do apologize you are having this issue with the Blackberry pearl 8100. Lovely device.
The manufactur, RIM is aware of the memory issue. It's a known malfunction of the device. Luckily, there's a way to fix it, and keep your pictures, logs, address book, etc.. from deleting.
First, you should have a 1GB card for your photos.
Second your phone stores what it does. So, when ever you exit an application press the back button. NOT the hang up button. It'll only leave that application running in the back ground.
Third, you can clear history by holding on ALT+LG+LG. You'll get an event log. Press MENU key, and select "Clear history".
Next, clear the cashe. Open up Internet browser, press the menu key and select clear cashe. Once you have done that, press the back button to the begining. Save all pictures on the memory card. If you don't have memory card, connect your Blackberry to your PC and use the desk top manager to sync your media over via USB cord.
Now, that you are connected via USB cord and have the desk top manager up, run application loader. This should take a total of 20 minutes. Do not REMOVE from the cord. You'll ruin the OS on the Pearl.
Once all is cleared out, and updated. Do a check on your camera, your call log, and sms's. Periodically, delete your text messages. I would say, once or twice a month run the application loader. You can always check out www.t-mobile.com/bbupgrade for the latest and great software for you Blackberry. Or, go to www.blackberry.com/btsc for tips & tricks!
RIM always updates their software every 2-4 months. That way you'll keep your Blackberry longer and stronger! Enjoy!
Cheers!
Feb 03, 2009 | RIM BlackBerry Pearl 8100
Deleted Third-Party Applications still show up on my home screen
What programs are they, and do you have desktop manager installed on a computer? (the cd that came with your phone.. i will walk you through it correctly.
For more assistance feel free to email support@RidAWreck.com someone will respond to your email in a timely manner. Our site is down for redesign but email is still fully functional. Upon the return of our site we with be offering great Blackberry downloads as well as 24/7 Blackberry assistance.
Jan 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry pearl troubleshooting
My phone does the same and i realized that it seems to have something to do with the yahoo messanger and the facebook mobile apps i have installed. It improved once i deleted any such messaging application even though the problem did not dissappear completely.
Jul 07, 2008 | Verizon Communications BlackBerry Pearl...
Reset blackberry 8700
my blackberry 8700g on/off ligt red
Apr 16, 2008 | RIM BlackBerry 8700c Cellular Phone
RIM BlackBerry? Curve 8330 Cellular Phone Logo
73 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
