Question about Dishwashers
I have a Jacuzzi Cara II, won't run.
I have a Jacuzzi Cara II. I beleive it model # is 4960000. serial #283274. I don't have an owners manual or any info on how it should operate. It won't operate at all. I filled the tub to about 4'' above the discharge ports and have checked the connections, all seems to be in order. The voltage coming in reads about 120V. Were do I go from here? Thanks, Sig P.
  • 641 Answers
SOURCE: Not enough water
Be aware that you should remove dishwasher's power cable before touching wires or making resistance measuring !!! Check that the inlet valve get power. In case it does and no water entering the tub, check with multi-meter for solenoid's resistance (disconnect first the wires to it),if no measurement result, you should replace the valve. In case you have a measurement result, remove the solenoid from the valve and check that it's clean from any dirt. In case there is no power to the inlet valve - check that the float switch works. This is usually a small switch attached to a float. The float (usually a cylindrical) located inside the dishwasher at the bottom. As the water level rises, the float rises too. When it reaches the certain height, the float activates its switch, which cuts the electricity to the water inlet valve. If the switch is defective (stuck in the disconnected position)it will prevent power from the inlet valve. The switch is an On/Off switch and you can check it easily by a multi-metr. Good luck !!
Posted on Jun 08, 2006
catriver
  • 878 Answers
SOURCE: Maytag Atlantis wont run
JC, sounds like the lid switch, check this first and post back..Catriver
Posted on Oct 30, 2006
SOURCE: Need Owner/Installation Manual for Fridgadaire Dishwasher
Go to: http://www.frigidaire.com/products/resultspage.asp?strmodel=FDB510LC
Posted on Feb 03, 2008
rickzilla
  • 706 Answers
SOURCE: Dishwasher not working
Difficult to say for certain exactly what will fix your problem but it is not out of the realm of possibility that the inlet valve is sticking closed.. The repairman may have given it a tap to free it up so that when it was energized.. it opened and let water in for the wash cycle..Just because that valve wasn't clogged doesn't mean it wouldn't stick.. If you can access it .. try giving it a light tap on the housing when the DW is cycling.. Hope that gets you going..
Posted on Sep 05, 2008
SOURCE: need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Posted on Dec 07, 2008
Need an Owners Manual for my 17.5 hp 42" cut Pony Troy bilt riding mower, Model 13AN779G766183630 Serial 1E045B30725000004
http://manuals.mtdproducts.com/mtd/Safety.do?pid=219561&model_num=13AN779G766&serial_num=&filename=769-01543.pdf
If you search on the MTD products website for any other manuals for this model, use 13AN779G766 as the model number and don't enter a serial number. Their online owners manual system is touch and go.
Sep 01, 2011 | Mtd Gold 13AA625P004 50Inch 502cc 230 HP...
I need and MTD owner's manual Model #2 Serial #
You manual can be found here:
http://manuals.mtdproducts.com/mtd/Public.do?model_num=2&serial_num=472612&doSearch=Y
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Mtd Garden
I NEED AN OWNERS MANUAL FOR A Whirlpool Certa Jacuzzi bath tub model # H526000
You can try this site it may help:
http://lawnandgarden.manualsonline.com/manuals/mfg/jacuzzi/jacuzzi_hot_tub_product_list.html
Oct 16, 2010 | Home
Need User Manual
Go to Jacuzzi.com and plug in model and serial no. you should be able to find an operation manual there.
Jun 09, 2009 | Whirlpool Caresse 2 Person Bathtub Seats...
Looking for manual for a jacuzzi model #9200
Jacuzzi has some archived manuals at [urlhttp://jacuzzihottubs.reachlocal.net/request-brochure/download-manuals.html][/url]
They also have a phone number you can call if you don't see your model manual listed. I was able to get an owners manual for my 94 Blue Ridge from them (even though my spa is pre-jacuzzi). It was a pretty generic manual, and they charged 5 bucks for it. It doesn't have any schematics, just operating info.
_________________
The light you see at the end of the tunnel is most likely Amtrak!
Apr 10, 2009 | Home
Dishwashers Logo
90 people viewed this question
Top Dishwashers Experts
Owen Barnes
