Question about Dell Dimension 2400 PC Desktop
Power safe mode on my monitor, i have dimension 2400 series
  • 1 more comment
  • Gabe Zevallos May 11, 2010
    Power safe mode usually comes up when the monitor isn't getting anything from the Video Card. You made need another video card or make sure that the cable is securely connected and the video card if it isn't attached to the motherboard.
  • M_Butkus May 11, 2010
    Does it go directly into Safe Mode ? Have you tried pressing F8 when starting and choosing "start normally"?
  • dbucyk May 11, 2010
    Did you want to reset your monitor settings through Windows or the monitor, or both?
    Problem Solver:
  • 11 Answers
After starting the computer start tapping F8 for advanced options, select " Last Known Good Configuration" with the keyboard and hit enter. If this does not resolve the issue than once again boot to the Advanced Options and get into safe mode.
Click on Start > All Programs > Accesories > System Tootls > System Restore and than click on next after selecting Restore Select a date which is in bold and on that day your computer should be working fine, after selecting the date click on next till the system starts the restoring. System will restart, Should work out.
Posted on Jul 30, 2009
I have a Dell Dimension 2400. It will power up but nothing will display on the monitor. monitor says it is still in sleep mode. The green power light is on and also the other green light flashes along...
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&SystemID=DIM_PNT_P4_CEL_2400
This a link to get an owners manual from Dell for your system, if you don't already have one. There should be a toubleshooting section as well as sugesstions on how to get out of modes. Ifyou need help with this, let me knowin "add comment' at end of solution.
Mar 16, 2011 | Dell Dimension 2400 PC Desktop
I have an older Dell Dimension 2400 series. I have tried running the monitor with it. I will get it up and running only after numerous restarts. Most of the time when I start up my system the monitor...
If it's an older 2400 series and you suspect it doesn't have a good signal going to it, I would try the monitor on a different tower to see if it's the monitor. If it isn't, I would recommend that you try to disable and change the VGA card in the Dell, if possible to a known good VGA card.
Also, try wiggling the connections at the monitor and graphics card, if this applies.
Or else, it might be a lost cause for that tower.
Good luck on getting the Princeton monitor working with your Dell Dimension 2400 series.
Aug 17, 2010 | Princeton Digital VL2018W Monitor
I have a Dell Dimension 2400 series that is very slow & freezes.
It sounds like you might have spyware on you computer. The two iexplore files might be spyware. I am not sure about the teatime.exe file but there is a file called teatimer.exe which is associated with the SpyBot software. I usually recommend Webroot Spysweeper software to remove and keep the spyware off of computers.
If you have software such as SpyBot I would disconnect the computer from the internet (after you update the software to the most current definitions) and boot the computer to safe mode. Log in as an administrator and run your software. This should pick up spyware before it has a chance to load.
Mar 09, 2010 | Dell Dimension 2400 PC Desktop
I am working with Dimension 2400 with monitor 773c blank or no display, drivers load after safeboot, but I am not sure what to do from there, nothing happens when I push enter, but the monitor works with a...
Refresh Rate, the reason why it works in safe mode and not normal mode is because in safe mode the system only loads the most basic and reliable drivers and sets the screen resolution and rate to their default values. In safe mode right-click on the desktop and go to properties, go over to the tab Settings and click Advanced. You should see another tab that says Monitor, there you can change your Hz, change it to something like 60hz to be on the safe side.
Jan 27, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 pc is extremely slow. did everything i know...delete cookies etc....still extremely slow.
Run your anti virus and anti malware programs. If you do not have a anti malware program go to cnet.com and download a free anti malware program. It sounds as if you have a virus on your computer
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
Monitor is in power safe mode... activate using pc. Machine buzzes and boots to #4 (appears in the front display panel).
try unplugging vga cable and connect it back then try reseating the memory chips if system has two memory chips try with one memory . if that doesnt work reseat the grahpic card if u have any and reseat the cmos battery .
Nov 20, 2009 | Dell Dimension 2400 PC Desktop
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
Feb 06, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 5150 Stuck In Pwer Safe Mode
Sounds like a problem with the video card. Cross check the connections to the CPU. If its all fine, Then Connect the monitor to a diffrenet pc and then use the monitors keys to change it to a plug and play mode.This might help with ur problem
Feb 01, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
213 people viewed this question
Alun Cox
