SOURCE: after spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
SOURCE: What causes the HE3t washer to stop in spin and rinse cycle?
Sometimes the unplugging helps, or hitting "Cancel" several times. Guaranteed to work though is to remove top, reach down the top to the door lock. (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door. This can also be accomplished by removing lower front panel and reaching up to do the same. BTW, while in the top, make sure all the electrical connections are tight. I found some loose before, probably from the spinning action.
SOURCE: whirlpool super capacity washer spin cycle stop working
Sounds like you need a new lid switch. Click HERE for prices.
SOURCE: KENMORE washer goes into spin cycle washer stops code f11 appears
unpug for 30 min, resets ccu
