HP Designjet 5500 (42 in.) InkJet Printer Logo
Posted on Jul 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The green and amber lights keep blinking
The printer is not working--
the green and amber lights keep blinking simultaneously, and the ink cartridge seems to be jammed to one side--
M_Butkus
Level 2:
Habit-Forming:
  • Expert 120 Answers
  • Posted on Jul 30, 2009
M_Butkus
Expert
Level 2:
Habit-Forming:
Answers
120
Questions
0
Helped
67045
Points
180
Check the HP site for the "blink" codes.
Epson 7010 all lights flashing & won't print
Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Fix the paper jammed
·Check empty or damaged ink cartridge
·Clean the dirty print head or replace missing or failed print head
·Read the steps to fix the Epson printer lights blinking error.
3helpful
Printer won't print. Green light blinks once, then turns amber & blinks 5 to 6 times, then turns green once again. I have replaced all new ink cartridges
5 times says the printhead is bad and needs to be replaced.The part number is stamped on the side so you can get the right one.
2helpful
Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
2helpful
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
1helpful
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Blinking green light
Clear the paper jam, or replace the ink cartridge. Possible causes are the paper jam or ink cartridge. The other solution is to disconnect the power from your printer and reconnect it. Hope this helps!
69helpful
7answers
New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
6helpful
4answers
Canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
2answers
Hp 1350 all-in-one
When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
k24674
Grand Canyon Tech
Grand Canyon Tech
