Question about Toys
I have a New Bright Bombadier XP Seadoo RC and the prop got tangled in a fishing line and two of the blades broke off. Where can I find a new prop?
5 Suggested Answers
bilink
  • 128 Answers
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Posted on Jul 14, 2009
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Posted on Dec 01, 2009
  • 3 Answers
the battery isnt lasting because it needs to be fully discharged (drained) before it is recharged. (this is only for nicd batteries)
Posted on Feb 22, 2010
  • 65 Answers
SOURCE: I have a RC Speed boat Sea Star and it has a
check at your loc hobby shop
Posted on Mar 31, 2010
One prop will not turn
if there's something tangled in it
Dec 31, 2013 | Walkera HM5#10 RC Helicopter
How do I take apart the New Bright Power Horse Tower Crane TC36 to fix the tangled strings inside?
WOO HOO I FIGURED IT OUT!!!! You have to pull it apart from the base up. First thing I did was take off the feet. If you look down the tower potion you can see a screw. Then u took off the tower. I figured out that if you just lined up the black square portion it would have come apart with just the one screw. Anyways now there is 2 more screws to get. 3 total to take the new bright tc36 tower crane apart. They are hard to see, but once the base is off you can get at em. Good luck everyone.
Jul 09, 2012 | Garden
Was fishing in heavy weeds with Minn Kota endura 50. I smelled faint electric burning and the wire & plug were hot. The unit stopped working. It this repairable at low cost or do I need a...
I have the same motor.That happened to me also luckily I only had a tangle of line I picked up in the weeds.Start by pulling off your prop and checking for something tangled around the shaft.If that is not the case,pull the front case off by removing the two bolts[they should be 10mm] and make shure nothing made its way into the lower unit.If all looks well reassemble and see if you can turn the prop shaft by hand if it turns freely with no noise try to run it.If it doesnt turn or makes a lot of noise chanses arethe electrodes that make the prop turn are out of place.If that is the case get back to me and I can take you step by step in resetting the electrodes.Good Luck.
Jul 17, 2011 | Sport & Outdoor - Others
I require a wiring diagram for a seadoo bombadier gtx 580 it is a1994 model
I looked up a picture of what your talking about and it looks like your talking about a jet ski? This section is for car audio, more specifically car amplifiers
Feb 24, 2010 | Car Audio & Video
Think it may be a line tension problem. every
Wow, I can't believe that. That reel is very simple and shouldn't do that. I would guess that it's a problem with the line. Usually a real like that comes with line. Sometimes line is bad and it's very twisted due to being the last on the spool before it's put on your reel. I would suggest you buy some quality line, like Trilene or Stren and use about 6 lb test. I like the limp kind (read the box and it will tell you what type you are buying). Limp line means fewer twisting/tangling problems. Good luck. Alley
Jul 26, 2009 | Sport & Outdoor - Others
How do we replace propeller on super cub?
The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
Jun 14, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
Trolling motor will not spin with out being turned by hand.
Take the prop off and make sure the pin that goes through the shaft is in place. The prop could also not be sitting on the pin proper.
Nov 29, 2008 | Humminbird 575 Fishfinder
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
