Question about Panasonic PV-DF2735 27 in. TV/VCR/DVD Combo
No audio channel four has no audio but has video. All other channels have audio and video.
    Brigadier General:
  • 4,090 Answers
Just check that the audio or this channel hasnt been set to zero and saved that way go to channel 4and select the volume up on the remote to ensure it is set to on
Posted on Jul 30, 2009
Why no sound in four rear channels?
depending on your equipment this could be because you have an stereo input and the output mode is not set to all channel stereo
Feb 20, 2016 | Audio Players & Recorders
Hooking sayyo tv to directv
Not sure if I understand what is happening here but if set on channel 4 the connection for the direct TV would have to be to the coax fitting on the rear of the set.
For the audio/video inputs on the rear or side it would have to be the same ones coming out of the direct TV box to one of the same but inputs on the rear--Audio/video are one connection and coax for channel four is a different one.
Dec 22, 2012 | Televison & Video
Can you get dual channel audio (four Chan) out of a toshiba l300 laptop?
Yes you can just grab a cable (both ends) male jack,like the male jack of the mic jack and plug one end to the PC and the other to your audio system
Apr 30, 2012 | Computers & Internet
My Lorex SV-01-RCV Wireless A/V instructions were lost in our move and I need help with the set up. Could you please help? I can not remember the correct connection.
You should have a 2-wire cable with Yellow, White and Red RCA plugs on each end.
The Yellow line is video out.
The White line is Left channel audio out.
The Red line is Right channel audio out.
Since your RCV only has two RCA jacks use the Yellow line for video and the White line for audio.
You should also have an "F-connector for co-axial cable.
If your TV set does NOT have audio and video jacks hook that to the co-ax antenna connector on the back of your TV set.
Set the RCV for either channel 3 or channel 4 and do the same with your TV set.
The RCV unit has four receive channels which must match up with the channel selected on the CAM or TX unit.
You can scan all four channels either by auto or manual.
If you only have one CAM or TX unit it probably doesn't matter which of the four you use unless you have a computer ROUTER which interferes with one of the four channels.
If so, select the 1, 2, 3, or 4 channel which has the least or no interference manually.
Bil Munsil
K1ATV HAM TV
Mesa AZ
Hams should be seen as well as heard.
Dec 30, 2009 | Home Security
I cant get our sony bravia to pick up signal for our SNES.. do i need a converter to use regula red white and yellow cables
no you dont but it could be the cord it self may need to be on a certain channel like 3 or 4 but most new TVs just have the VA [Video and Audio RED WHITE YELLOW CORDS] are just options for different deviced so theres no need to have it on a channel,
haha you may need a coax cable to the CABLE PART OF YOU TV AND PUT IT ON CHANNEL THREE OR FOUR AS DESIRED! the coax cables for super nintendo are cheap and can be found easliy at sum local shops who invest in older{ but needed] items for video game systems! so yeah i guess the AV [ audio and video thats the way its abbrivated\] may not work just cause of the older system! ebay may have sun but i dont really like the bay for things i can buy at my local pawn shop
Dec 25, 2009 | Nintendo Super NES Console
Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Sep 23, 2009 | Sega Genesis Console
How to wire a sony xm-444 car audio amp so that it is a 2 channel 222w amp
Your amp is a four channel so you have 4 sets of speaker outputs. to bridge this amp to 2 channels is pretty simple, all your have to do is when connecting your speakers instead of using both +, and - from the same channel, use the + from the one channel, and the - from the adjacent channel. Do this for both speakers, if you'll notice you now have 2 empty - terminals and 2 empty + terminals, if so you did it right... Hope this helps, enjoy your amp.
Sep 17, 2009 | Sony XM-444 Car Audio Amplifier
XL1s and 4 channel audio
Hi!
Unfortunately, Premiere Pro CS3 can only handle two channels of audio at a time when capturing. You could try capturing with Scenalyzer or another program that can handle four channels simultaneously.
Hope this helps!
Nov 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Trying to rewire cartridge
Red - Right Channel +
Green - Right Channel -
White - Left Channel +
Blue - Left Channel -
Regards
John w
Jan 30, 2008 | Audio Players & Recorders
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Panasonic PV-DF2735 27 in. TV/VCR/DVD Combo Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
