Question about Epson LX-300+ II Matrix Printer
Printer installation changes cable to usb.. installed through printer and faxes.... printer was installed successfully but can't print... what do i need to do? is there any update needed?
    Sergeant:
    Novelist:
  • 198 Answers
Check on Control Panel-Printer Properties-Ports tab.
Make sure that the port selected is USB 001 and not LPT1.
Posted on Jul 30, 2009
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Sep 20, 2011 | Epson Passbook PLQ-20 Matrix Printer
My HP OfficeJet J6450 stopped working after getting a paper jam. It is connected with a USB cable. I have tried deleting the printer and reinstalling the software without success. The software...
When installing the printer click on local printer and uncheck the box below it. I think it says something like locate my device. then on next screen click create new port, you should see USB001 in there.
Jun 09, 2011 | HP OfficeJet 6310 All-in-One Printer...
My Brother MFC-5890CN Printer wont print.It does scan.I have tried re-installing the drives but when it gets to the last section the box just asks for the machine to be connected. I have also changed the...
I can't print nothing from my PC or trough network, but still I can Scan, Fax, etc. I'm using Windows 7 Home Basic, I already installed the driver ( "Connection via USB Cable" ) and I have plenty enough ink ... I checked the Settings, Test Page is OK, but nothing else want to be pinted. I had a problem with my MFC 5890 in the very begining ( nearly 2 weeks ago ) so I had to unplug and than plug in the USB Cable and in this situation the printing of my "pending documents" was successful, but from few days ago there is no such a thing that could make it print. Please help
Dec 31, 2010 | Brother MFC-5890CN All-In-One InkJet...
Not printing
Don't connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | HP Deskjet 3420 InkJet Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
Help
Check whether you have successfully installed the software or not and then check whether you have the printer icon in printers and faxes folder. if we do not have the printer icon then remove the USB cable from the computer and then insert the CD and click on add a device option and follow the onscreen instructions and connect the USB cable when prompts and then try to print. If we have the printer icon check the status, if the status is not in 0 ready then clear all the pending documents and then print. If we are still unable to print then download the print diagnostic utility from the HP website and run it.
May 20, 2008 | HP Officejet J5780 All-In-One InkJet...
Printer will not print
Some thoughts.
When you plug it into the computer that it will not print to, Does it tell you there is a new USB device found?
2. I am sure you have tried different USB ports on the computer.
3. Right click your printer to access the properties on the driver and select Ports and see if that somehow was changed.
4. Just delete the printer from the "printers" page in control panel.
Then click add printer and search for it.
5. Make sure the computer does not have a firewall that is blocking the printer.
6. Make sure there is no job error in the print queue.
7. Be sure the printer is selected as the "Default" printer. If there is another printer loaded on the computer, is the wrong one selected?
8 Make sure Print Pause is not selected.
I do suspect once you open the properties on the driver page you will find the problem. Unless of course your USB port or ports on the computer have failed.
Dec 14, 2007 | Samsung SCX-6320F All-In-One Laser Printer
Epson LX-300+ II Matrix Printer Logo
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
