SOURCE: No ringtone or caller id
Press Call Button
Press Blackberry Button
Scroll down to Options
Go through options to see if there is anything obvious.
Gadget
SOURCE: i can't unlock by iphone
Have you tried rebooting it?
hold down power and the button on the bottom till it shuts down, then turn it back on, that fixes mine. I hope this helps you!
SOURCE: Phone wont ring
Per the manual, If there is a musical note in the display with a slash thru it, you have turned off the ringer. You have done this by pressing and holding the # button.
If you have the manual it's on the bottom of page 20 and continues on 21.
If not follow these steps.
Press Menu
Press CID/PBK (Personal set)
Press Menu (Handset Tone)
Press Menu (Ring Tone)
Press Menu and then CID/PBK to select the volume you want
Press Menu (Save Setting)
click this link to get the manual
http://www.p4c.philips.com/files/c/cd4452b_37/cd4452b_37_dfu_aen.pdf
SOURCE: my i9 phone's slide to unlock feature wont work
THE I9 IS A JAVA BASED JAVA APP PHONE THE JAVA APP THAT RUNS THE SLIDE TO UNLOCK FEATURE HAS MALFUNCTIONED THE ONLY WAY IS TO HAVE A TOTAL FIRMWARE RESET BUT AT THE MOMENT CECT ARE NOT SUPPORTING THIS YOUR ONLY HOPE IS TO CONTACT THE SELLER OF THE PHONE AND TRY TO GET A REPLACEMENT HOPE THIS IS OF SOME HELP THERE IS A CECT FORUM IF YOU SEARCH GOOGLE
SOURCE: CANT ANSWER IPHONE
you most likely have a hardware issue that needs to looked at by a pro at an apple store. you could also perform a reset by holding the power and home screen buttons until the phone resets.
