Question about Miele CVA615 Espresso Machine
My miele espresso maker dispenses too much water in my espresso. how do I fix this?
    Problem Solver:
  • 9 Answers
If you fill two esspresso cups at the same time it should be the correct size. But if it is weak, see below...
For one cup, press the small coffee button to start. Press the button again when the desired amount of espresso is in the cup to stop the flow. if it is too watery but the correct amount see below.
If the espresso is too weak push the coffee grinds slide switch inside one notch finer and make another 3 cups. If the flavor does not get strong in 3 cups then there is an anomaly happening. The brew unit upper filter has gunk clogged behind it to a point where the pressure (230psi) of hot water trying to get through the gunk pierces a small channel through only a portion of the filter screen. All the water is running through only 4 or 5 holes in the filter screen. This eddy allows hot water to pass most of the grinds without extracting flavor. It's the same as if you clogged a sink strainer then pushed the blockage off part of the strainer. The water goes around the coffee not through it. The path of least resistance.
Remove the upside down stainless steel filter on the brew unit- Remove the screw using the allen key that came with the machine. It goes through the little finger nut on the top of the brew unit. Turn it counter-clockwise (lefty loosy) and the filter will come off from underside. The area behind the filter screen has to be cleaned of any coffee residues. Also check thew creme valve. It is under spring tension accessible from the top of the brew unit by removing two screws holding the long pipe on top. be careful not to let the spring shoot out and loose the creme valve. It looks like a plastic rivet on the other end of the spring. Clean out the entire channel by rinsing. Use a pipe cleaner for dried on grinds.
Note: the finer you set the grinds the quicker it clogs the filters. Increase the use of cleaning tablets when you grind finer coffee. A clogged brew unit is almost impossible to clean even for the most handy of people and the last I checked a new brew unit is well over 200 bucks! Good luck!
Posted on Oct 19, 2009
My miele coffee maker CVA 4070 dispensing tubes are clogged
I had this problem ... you need to remove the dispenser from the rear of the door. Then once removed clean in running water. Its a sealed unit but you can squirt high pressure water inside to dislodge the coffee sludge. When clean .. fill with water and make sure the 2 spouts drain evenly. regards
Jul 09, 2014 | Miele CVA4070 Coffee Maker
The coffee dispenser leaks out in other places
I've got the same problem on my CVA 4075... Coffee comes out all around the dispenser not so much through the tubes. How do I get this part out to clean it?
Mar 17, 2014 | Miele CVA4070 Coffee Maker
Miele coffee maker water not coming through to brew unit
try cleaning the nozzles using fine wires or tobacco pipe cleaner kit. it look like you have a blockage on your tubing leading to nozzles.
Nov 06, 2013 | Miele Coffee Makers & Espresso Machines
Water is not dispensing
does the machine ask you to fill water? If it does check to see if the float is secure and still inside of the water dispenser. It's a small compartment inside the water dispenser that houses a float with a cap to seal it in.
Oct 03, 2013 | Miele CVA615 Espresso Machine
At first my Miele CM5000 worked perfectly. When I pressed the espresso button, a perfect espresso would come out- the machine dispensed the correct amount of liquid then stopped automatically. Now, the...
If the espresso coffee outputs too much water and doesn't stop, there is an easy fix. The quantity adjustment for the machine is off. After looking through the user manual, I found out that you could press and hold the espresso button, and then follow the on-screen instructions where you can specify the quantity poured.
Aug 03, 2013 | Miele Cm 5000
I have a miele cva620 ind it displays expel air.. what shall i do? how can i do it?
FIll the water tank.
Turn the program selector to "ON with light" and place containers below the hot water dispenser and the steam nozzle.
Press the hot water button, turn the steam selector counterclockwise and let water run out until it streams steadily.
Press the hot water button again.
Turn the steam selector to "o" to shut off the water.
That should solve the problem
Jun 25, 2009 | Miele CVA615 Espresso Machine
De-scaling
Try doing descaling with a descaling product , like the ones below:
Urnex Cleancaf Coffee Maker Espresso Machine ...
$9.99 - DBROTH
Miele Coffee Machine & Steam Oven Descaling ... $20.55 - Totalvac.com
Apr 19, 2009 | Keurig B60 Coffee Maker
No coffee dispensed and no water comes out when Rinse selected
1st use cleaning tablets used for brew unit. and go on cleaning procedur.
2-the sound you hear i think is only motor of
grinding
thank you
Mar 24, 2009 | Miele CVA615 Espresso Machine
Miele CVA615 remove coffee bean dispenser?
their is a plastic screw below the bean dispenser .once unscrewed you will remove the dispenser
Jul 13, 2008 | Miele CVA615 Espresso Machine
Clogged Dispensers
Sounds like a burst water line inside, if you made sure there is water available, and you hear it pumping. Either that or a solenoid valve is not activating. Must remove unit and pull the cover to investigate.
Jan 10, 2008 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
623 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
