Hi, Your problem might be, 1. with your mobile phone service provider 2. With your friend's mobile 3. With your mobile itself
To sort out problem 1: Use some other network sim card and try it.
To sort out problem 2: Call to some of your other friends and test it
To sort out problem 3: Use headset connected to your mobile and test it by speaking to your friends via headset. If works fine, then there is some problem with your mobile phone speaker. Test the call using loudspeaker as well. Test the call using a bluetooth headset as well ( if one available with you)
So by the above method you can find out where about your problem is and place a service order to your mobile if needed. I hope this is helpful to you Thanks
When you are receiving the file, check whether you have checked the Visible to other option. And it will ask for the confirmation when you will be receiving the file from other phone whether to accept or not. While sending the phone to which you are sending data should accept the file you are sending.
the interface between motorola and sony ericson works only in some models..try some other headsets (of your friend's ). of the same company.if it works then its not possible to connect the device
My bluetooth does not work at all. Have had it on charger for days. It does turn purple, but does not work when I put it in my ear. Have checked the connection. It just seems dead. Bought it last November, but first time I've had a problem. Can you help?
Barbara
