Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Nothing happings I just plugged in my new tv and sat down to program the channels and it just went out.  When I pushed the power button, I get a "popping noise".  I had it plugged into a surge protector.  Please help, it will not come on. mitsubishi vs 4542 projection tv
  • jen_1106 Nov 27, 2007
    It is September 1995
  • floyddean Nov 12, 2008
    same problem as jen-1106
No picture, popping sound after turned on, about 6 secounds later please help.
Posted on Nov 12, 2008
    Genius:
  • 1,694 Answers
Jen, Please verify Model # and mo / yr off the label on the back of your new set.................................T.
Posted on Nov 24, 2007
  • Vista Electronics Nov 27, 2007
    jen, Please be advised your set is past spending good
    money towards fixing.It may be new to you,but as you stated,
    it is over twelve years old.......probably cost 300-400.00 to fix..
No signal
try first if you have not to remove set and any cable or sat box from power, a box etc can cause this--when you plug back the units will try to reboot, cannot hurt and may help.
Jul 19, 2013 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
On tv 2 the remote controls the volume and power but will not change channels or do anything else. went to system info in tv 1, pressed sat and power. This did not help. Batteries are new.
Hey, Jane!
I can definitely help you with this. Go to the System Info screen like before, but on the TV2 remote press the 'Record button and see if the number in 'Secondary Remote Address' changes. If it doesn't, let me know here, and I will assist you in programming it!
Tommy Faust
DISH Social Media Representative
Nov 07, 2012 | DISH Network IR Remote Control
Bought a new TV now the remote won't talk to the sat box
Hi mgreaper my name is Mike Houston of DISH Network there is a way toprogram your DISH Network remote to your new TV. What you can do is what wecall a "power scan" and it finds the code for your TV to our DISH Networkremote, The first thing you want to do is hold down the clear TV button for 6seconds and then push and release the big red Power button and press andrelease the Channel Up button until the TV turns off and then stop. Then youwill want to press the # button and press the red TV button and make sure yourvolume and mute are working. I will send a link to help with the Power Scan. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Feb 05, 2011 | DISH Network IR Remote Control
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
Nov 23, 2010 | DISH Network IR Remote Control
I DROPPED MY REMOTE AND THE BATTERYS CAME OUT AND NOW I CANT TURN THE CHANNEL SO I NEED TO KNOW HOW TO PROGRAM MY REMOTE
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Cannot find manual. need to program menu
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Brookstone 538744 Remote Control
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Echostar IR remote (Dish)
to set remote to tv
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
