Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher not always draining
We just moved into a new house a few weeks ago. The appliances were left by the previous owners. The dishwasher is a GE brand model number gsd5610d00ww. The dishwasher doesn't always drain. Their is about an inch of water left . Also, we heard a beeping noise a few times but haven't heard that noise for a coule weeks now. Not sure if this is related somehow.
  • 1 more comment
  • Anonymous Nov 24, 2007
    dishwasher does not drain
  • sabdzine35 Feb 27, 2008
    We just installed the Triton and it won't drain either. I emptied the water and ran the normal cycle. While running I was running the sink and garbage disposal which begain to back up. The water would drain very slowly from the sink, but still wouldnt drain properly. Is there other suggestions I would hate to call service if its a drain issue
  • Duckieboy03 Jun 26, 2008
    Have the same problem with the dishwasher not draining. It is connected to the drain line in my sink. We always have an inch of water in the bottom of it. It still washes well, but I'm concerned that it is useing old water to clean our dishes. I thought that water was backing up from my sink so I retied the drain line from the dishwasher to the sink with an upward bow in it...still holdes water in the bottom!
If the dishwasher drains through the vent pipe on your sink it may be clogged. I had that problem as well. Unscrew the vent cap and look for junk. In my case of all things it was dog hair!!
Posted on Nov 24, 2007
Samsung dmt800rhs errorcode se
I had this issue; previous owners of our house installed new garbage disposal, but did not punch out the plastic stopper on the disposal where the drain hose connects.
May 12, 2012 | Samsung DMT800RHS Dishwasher
I Have a Hotpoint BCI450 - it was conneccted by a previous owner and we do not have the instructions. A few nights ago the washer stopped washing 1/2 way through a progaram leaving a few inches of water...
The problem is associated with the main program controller unit and so it is needed to remove the panel and see if there is any moisture present that had caused the error.
Leaving if off overnight would have resetted the machine or made the panel OK.
So after cleaning if the panel does not work to trigger the inlet then the controller unit must be checked.
Please check on the links below for some tips:
Sep 02, 2011 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
We moved to a new house with or GE EDW6000. The dishwasher wont drain all the way. about 3-4 gallons left in bottom. The new house has an air gap under the sink that is lower than drain hose Could this be...
i had the same problem with mine .turned out to be the pump drain not the pump itself .there was glass stuck in the little propellors.once i removed the glass it worked fine
Mar 19, 2011 | Maytag Dishwasher
Dishwasher smells has a 'wet dog' smell
its the food and the steam together. its normal.
Aug 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher did not drain out all of the water
run it again on the hot cycle...if that doesn't have a clogged drain hose or a defective pump.
Apr 04, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher not draining
you got a high end GE there unless this happened right after a new garbage disposal was installed you should call someone on this heres a picture of ur wash and drain assy.307 houses 2 check valves 325 is the drain pump which has its own check valve it worth the service call to let a repair man fix this if it happened right after a new garbage disposal was installed the forgot to knock out the k\o its a plug on the g\d were there drain hose hooks to a hammer and screw driver will knock it out hope i helped ya let me know peace.729883f.gif
Feb 24, 2009 | Dishwashers
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Potscrubber GSD900G01Dishwasher
I have found a parts breakdown and it looks to me that you are missing the front wheels.
The following link will show you a parts breakdown.
Post back.
Jul 01, 2008 | Zanussi 24 in. DE6965 Built-in Dishwasher
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
232 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
