Question about Samsung HL-P6163W 61" TV
Bug in screen
I am having the exact same problem with my samsung. There is a dead bug caught in between the screens. Has anyone tried to clean this?
  • jeffmax Jul 30, 2009
    Thanks for the help. Unfortunately, when I looked inside via the port you described, the bug is definitely not on the inside either, it has somehow become squashed between the lens'.
    Novelist:
  • 85 Answers
It is unlikely the bug got between the inner Fresnel lens and the outer cylindrical disperser lens of this DLP as the separation is minimal and blocked off all around. Much more likely is that is inside the Fresnel lens and may be cleared off with a clean microfiber cloth through a port to be found on each side (guessing) of the set. Try not to add dust. You can also go to avsforum <http://www.avsforum.com/> and search for Samsung HL-P6163 or similar 5-year old. -Ken
Posted on Jul 30, 2009
  • Kenneth Klare
    Kenneth Klare Jul 30, 2009
    While trying to clean it, gently lay the TV face down on a clear cloth so the bug does no fall on color wheel or bulb.
    -Ken
I think my Samsung Galaxy Tab 3 10.1 has a bug. Please see more details below. I've done everything I can think of, to no avail.
Check out the troubleshooting section in the manual.
Check your apps to see if you have any malware programs you can load and run
Samsung
Mar 07, 2015 | Samsung Galaxy Tab 3 16GB 10.1-Inch White...
There is a black horizontal line on my samsung NP900X3C. Is this a software bug or hardware malfunctioning?
most probably bad video screen or video screen cable.
You can try resting the computer to original factory settings but I thinks it's hardware
Oct 29, 2013 | Samsung Series 9 NP900X3C-A02US 13.3" LED...
In my samsung Gtb3410 mobile videos are do not play in full screen, what can i do for make it full screen.
Sorry to say this,this is a bug in samsung gtb3410...But you can install smart movie player and set it to full screen mode...
Jan 19, 2011 | Samsung B3410 Cell Phone
Most times when i turn on my computer, the screen flashes.
it means your computer has caught the ati2dvag bug. This bug seems to affect ATI video cards.
The 2 most common “solutions” are:
  • Reinstall the ATI driver. You are advised to launch Windows in Safe Mode (press F8 before Windows boots), go to Windows Add/Remove programs and uninstall everything ATI. Remove the DAO/MDAC component as well. You can use the ATI removal tool utility which can be downloaded from the ATI website. The complete set of instructions on removing ATI can be found here on the ATI website.
  • Go to System Devices in My Computer > Properties > Hardware, and locate the option, PCI standard PCI-to-PCI bridge. This could under other names on your PC, so contact your PC vendor if you’re unsure. Right click, and select the “update driver” option. Manually search and install the PCI standard PCI-to-PCI bridge.
Jul 06, 2009 | ViewSonic VX910 19" LCD Monitor
Bug behind plastic screen cover and loose right side movement
Sadly the entire system needs to be taken apart. There is going to be at least 15 screws to remove and you need to move with surgical precision.
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 14, 2009 | HP Mini 1035NR Notebook
Grey spot on screen
It's not the lamp. It maybe dirt or dust or even a bug. The picture that is projected starts out 1/2 inch by 1 inch in size. Somewhere along the path to the screen a piece of dust gets in and after it's projected it looks like a blob on the screen. The closer it is to the DLP chip itself the bigger it looks. If this is the case you should have a professional service it. The Light engine needs to be removed and cleaned.
If you lightly push on the screen does the blob move slightly ? If it does it's not on the screen it's in the optics or the mirror.
You may also have a bug or smug on the main mirror that causes the same thing. This will appear about 2 times the normal size of the object. If your up to removing the screen Take a look closely at the mirror on the back of the set. You can clean this with windex it's glass. If you do take the screen off hold it up to the light. Sometimes spiders make webs and leave marks.
Good Luck
Apr 19, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Monitor strip down got a bug dead on inside of my screen
HOW CAN I REMOVE THE PROTECTION SCREEN TO CLEAN A DEAD BUG BETWEEN DE PROTECTOR AND SCREEN TV
Aug 11, 2008 | RCA HD52W59 HDTV Projection Television
Beeps when turned on then power light blinks 5 times
sound like the b+ line is not getting the voltage call a tv repair tech.
Feb 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Protection Screen
if your can see the bug chances are its either on the crt lenses or on the tube assy,remove rear panel and inspect to see if the tube can be cleaned with a dampend cloth make sue the set is off.
Sep 09, 2007 | Hitachi 50EX01B 50" Rear Projection...
Samsung HL-P6163W 61" TV Logo
223 people viewed this question
Jerry Greenberg
Jerry Greenberg
