Question about Watches
My sportline watch resets itself during exercise , and reset everything back to zero even the date goes back to 1-1 always. Everything stops counting, steps, calories, mph, miles walked, everything
  • 65 Answers
I don't know this watch personally but it sounds like it may be a short circuit or maybe one or two of the buttons may be being activated during a particular movement. I'd recommend you take it to a watchmaker for diagnosis.
Posted on Jul 30, 2009
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
Need to replace battery on sportline watch the number on back is 4136
Most likely a CR2032 Lithium, the how part is take off the back, remove the battery holder and old battery. Observe the polarity so you put the new one in correctly. You may need to do a reset which is very difficult to try and tell you what to do but none the less may need to be done. Put everything back making sure the gaskets are aligned properly. You will probably need a very small phillips screwdriver. This is actually my second recommendation. My first is take it to a watchmaker that does hundreds of these every year.
Oct 11, 2012 | Sportline 925 Heart Rate Watch
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
The heart rate function has turned off. So the calorie count won't work. Everything else is working fine. It happened about four days ago. I have lost my owners manual.
Press and hold the reset button, for 5 seconds, while in Time mode. this will reset the heart monitor and the symbol will reappear on the screen.
Nov 26, 2010 | Sportline 915 Solo Heart Rate Watch
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
I am trying to set a digital watch, there are 4 buttons 1=light 2=mode 3=start&stop 4=lap reset. I can not find the name brand and I bought it at a second hand store for my grandson. The only name I...
mcdevito75here, I'm sue I can help you set this digital watch,----4 buttons, 1=light, this should be just for the light built into the watch, 2=MODE this is the button you press to set the functions, press this button and see everything flashing 3= Start Stop this button should act as set after you press MODE it should also be to start the lap counter and 4= lap reset this should bring the lap counter back to zero or the seconds tick normally.---- press MODE see everything flashing, then press start stop to set functions, hour, minute etc, press MODE after you have set each function, hour, minute, etc. When done with all functions press mode again to bring the watch back to normal operation.
Jun 23, 2010 | Watches
Lost manual Sportline heart rate watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SPORTLINE watch manuals. Rate me, please.
Feb 26, 2010 | Sportline C9 by Champion Fitness 910 Watch
How to reset the chronograph hand back to zero (12
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get cheap wow gold with the lowest price wihit in
10 minutes' fast delivery and you also can enjoy first class service
for your login.
Jan 08, 2010 | Omega Speedmaster Day Date 3520.50.00...
Sportline watch
Love my watch, Was placing it on wrist, time correct, pressed button to test pulse and everything went blank. Pressed reset button, with no effect. It has a high pitched whine when placed at ear.
Does this mean I need a new battery, and where is that done, so I don't mess it up.
Appreciate any help as I don't have the instruction book either,
Scotty
Feb 22, 2008 | Sportline 1000 Memory watch
Frozen Display
The reset will always solve the issue. It may have been due to Electromagnetic Interference or Static Electricity.
You can press and hold ALL buttons at the same time for 10-15 seconds. After that, simply reset the time/date. All saved information will be stored.
If you are still having a problem feel free to contact Polar Customer Support @ www.polarusa.com.
Hope this helps.
Chris @ Polar USA
Nov 08, 2007 | Polar F6 Wrist Watch
Watches Logo
127 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
