Washing Machines Logo
c
connie laxton Posted on Dec 16, 2017
I was running the rug docter and it started making a loud strange noise and it seemed very hot to the touch on the top surface..Is there something that I'm supposed to do?
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Aug 25, 2007
SOURCE: Sharp CVP10MX started to make strange noise periodically
What type of noise. Fan noise or compressor noise?
Anonymous
  • 331 Answers
  • Posted on Nov 02, 2007
SOURCE: loud noise
First, UNPLUG YOUR DRYER! Now open the dryer door and remove the 2 screws at the door hinges... remove the door and set aside, then remove the 2 screws opposite the hinges. Grasp the front panel near the top, just below the top panel and pull it toward you... do this on both sides. Tilt the panel forward then lift it off of the lower clips.
With the front panel gone, you'll see a 5/16" screw just below the top panel on both sides, top left and right. Remove these and the clips too... now you can lift the top panel like the hood of your car.
To gain further access, remove the 6 (3 on each side) screws holding the front drum support/blower vent panel, then set this aside.
If you want to remove the drum... first, take a flashlight and look closely at how the belt is routed around the idler pulley and the motor shaft. (You'll have to re-route it for reassembly.) Reach in there with both hands, with one hand rotate the spring loaded idler pulley back to release tension off the belt, then with the other hand remove the belt from the motor shaft. Now lift and pull the drum out the front of the cabinet.
Check to make sure the rollers in the back rotate freely. You can remove the rollers, buff the roller shafts with emery cloth, lube the shaft with light oil (like sewing machine oil) and reinstall the rollers. Lube the idler pulley also. Rotate the motor by hand and listen for the squeak you described.
Also check the front drum support panel you removed earlier. The drum rides on this as it rotates... As you are looking at the drum support from the drum side, inspect the 10 o'clock to the 2 o'clock area closely. If the glides (teflon) are worn it'll squeak when it rotates.
Hope this helps. Oh yeah! Almost forgot.... the belt won't squeak at all. It'll be the motor, rollers or drum glides.
Anonymous
  • 4 Answers
  • Posted on Dec 02, 2008
SOURCE: 96 lincoln town car- loud humming noise
I had experienced the same problem with my 93 TC. I'll try to make it short. Replace the Idle Control Valve. Cost me $50 at AutoZone. It has a electronic plunger that has a rubber o ring on the end of it. It separates two air chambers inside the valve. When the rubber gets old and the plunger is suppose to cut off the air coming in from one chamber to the other, the air gets sucked between the chambers across the old rubber causing the humming noise. That is also why the engines revs up and down and wont idle right. It is located between the firewall and the back of the motor just to the left (drivers side) of the throttle control assembly. When you look up on the internet on how to replace it, it will tell you to remove all the housing surrounding the wiper blade control arms and assembly so that you can access it. If you take your time, just remove some of the hoses and wires connected around it and you can access it without removing all that ****. Only has two screws to it that point up and can be reached with a ratchet and extension. Car runs great now and finally got rid of that noise.
Anonymous
  • 145 Answers
  • Posted on Dec 14, 2008
SOURCE: Top drawer of dishwasher has a loud pump noise while running
Look for burrs on the botom impeller of the rotor. it requires no tools to check this. Take the wash arm and filter plate off, now rotate the motor rotor's base counter-clockwise and pull it out. Inspect the greay impeller closely for any nicks or burrs. If any are present, the impeller will make a LOT of noise. If it needs to be replaced, you can find them at fisher paykel parts, here is a link to the part you will need:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=9
kachbibi1
Bill Dickerson
  • 979 Answers
  • Posted on Jan 14, 2009
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
My Shark Navigator, makes loud noise when switched to carpet. It's not clogged and there isn't any hair wrapped around rollers. How can I troubleshoot this?
They are all called 'Navigator' :>D
https://www.google.com/search?q=Shark+Navigator
When switch to carpet, the difference is that the brush roller turns. When it is on hard floors setting it doesn't. Remove the base plate, remove the brush and the belt. There is likely something wrapped around the drive spindle or clutch.
How to reduce high pitch noise of Shark vacuums
Digital Trends https://www.digitaltrends.com > Smart Home > Guides
Apr 6, 2022 - You can adjust the height on a Shark vac to accommodate certain levels of rugs, carpet, etc. If the vac has been set too high for the current ...
Loud rotating carpet brush noise: Just got my new Shark
Fixya https://www.fixya.com > support > t15932203-loud_r...
It seems that your drive belt for the beater brush is stretched. This is a common problem -- if you flip the vacuum over so you are looking at the bottom, you ...
4 Reasons Why Shark Vacuum Is Making Noise
howtofixit.net https://howtofixit.net > shark-vacuum-making-noise
Aug 20, 2021 - Another cause behind the loud noises coming from your Shark vacuum is an overly dirty or damaged filter. Remember: air must be able to pass ...
‎Loud Or High Pitch Noise · ‎Blockages · ‎Rattling Noise · ‎Belt Snapped In Powerhead
Does anyone know why my vacuum might be making a ...
Reddit · r/VacuumCleaners 10+ comments · 2 years ago I agree, suction relief valve is popping because of a blockage. Check the extension wand too. The air goes from floor head, lower hose, ...
6 answers · Top answer: That's the suction relief valve. There is a blockage somewhere in the system, either in the ...
Loud Air Coming Through Side Vent, Brushroll Not Spinning
Dec 4, 2020
How to fix this without taking it in? Shark vacuum - Reddit
Sep 27, 2022
Shark making weird suction noise : r/VacuumCleaners - Reddit
Aug 13, 2022
Shark Vacuum Making Strange Noise and Not picking up Dirt
Sep 22, 2022
More results from www.reddit.com
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
When in carpet mode, brushes seem to be hitting something. Brushes cleaned - how to stop making the awful noise
LOL do you mean when you move the vacuum forward (say into a baseboard)? it makes the loud shocking noise.. i hate that too.. but that's the crazy Warning sound indicating something is stuck (like you sucked up an area rug) or you have run into something and it set off a sensor.
1helpful
Noisy
Check to make sure the fan is not hitting anything, if the fan looks good then on the back oof the unit is a relay, check that and make sure all is well. If both check out ok then I would get to work on the compressor and make sure it is not HOT to the touch and that it is operating correctly.
Please rate and let me know if you need more help
Top Washing Machines Experts
john h
