Question about GE Hotpoint® HTS18GBS Top Freezer Refrigerator
Slight gap between gasket and door. Only in one spot.
My Hotpoint HTS18GBSAR refrigerator has a slight gap between the gasket and door on the top of the door. The door will not close properly and the light stays on inside. The light is visible through this gap. It is only in one spot, the rest of the door seals fine. Any suggestions? I have tried readjusting the gasket by physically prying it up slightly with my hands and that helped a little bit but it is not permanent. I checked the floor for level and it actually pitches down towards the back. Thanks.
Sea Breeze
  • 4654 Answers
SOURCE: weak magnet top seal
Click the link below and go to line 7 and then line 33, Thanks Sea Breeze
http://www.applianceaid.com/refrigerator.html
Posted on Oct 27, 2007
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
SOURCE: freezer door on GE side by side stays open slightly at top
i have kenmore side by side model 52552100 and the ice maker will not send ice thru the door. I is not even making any sounds when I push the button dispense. Can you duplicate this problem
Posted on Apr 10, 2009
SOURCE: Freezer never cools consistently and compressor never goes off
my ge tps28bb profile side by side refrigerator freezer has warm temp ,how can i fix it?
Posted on Jun 26, 2009
VtToolMan
  • 704 Answers
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Posted on Aug 03, 2009
How do i replace a top freezer door gasket
Hey friend, thank you for your post!
On a top mount Frigidaire refrigerator the gasket is a magnetic strip which should be able to be easily removed. You would have to order a new gasket for your refrigerator which you should be able to reach out to the manufacture for part number and availability.
If you need any additional assistance with replacing the gasket I would recommend reaching out to a professional for proper replacement. Hopefully this information is helpful. -Matt
Oct 04, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
On our Fridgidaire refrigerator - freezer door comes open
Good day,
When you close the fresh food door, air is pushed in, and forced into the freezer compartment.
Check to see if the machine is leveled. Slight tilt to the rear is ideal.
If the freezer door fits properly, then usually it is weak magnets in the door gasket, and the door gasket needs replaced.
There are specific details on how to replace a gasket. A qualified counter-man at an appliance parts house will explain the details.
Very important.
Nov 09, 2009 | Refrigerators
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
The freezer door has a slight gap at the top between the gasket and the body of freezer allowing air to get in. What do I do?
Replace the gasket.
Your local appliance parts hose should have them in stock, and if not can likely order them.
This is a common problem and quite easy to fix. Most gaskets are simply pressed into a seam in the door. A few are held in place by simple metal brackets than can be removed with a screwdriver.
Aug 24, 2009 | Haier (492420265334) Refrigerator With Ice...
Door gasket gap
Hi, Try rolling up a piece of paper towel and place it behind the door gasket to stretch it. It might take a few days to stretch.
I hope this helps.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Refridgerator/Freezer will not get cold
Check to see if the refrigerator is clean at the condensor at the bottom or at the top of the unit. All fans running inside and outside the unit? Door gaskets sealing tightly. Put a dollar bill between the door gasket and cabinet and clost the door. Slight drag ok. No rsistane, bad gasket. No solution at this point, call for service.
May 04, 2008 | Magic Chef CTF2125 Top Freezer...
Concaved out freezer door
If concave is severe you will have to replace door. You can try to alleviate a slight gap by using a hairdryer and blowing hot air on the gasket in the area of the gap....move the dryer in up and down motions and the gasket will expand! Just make sure that there is no ice pressing against the door inner first! Oshie
Jun 18, 2007 | Maytag MTF2195AE Top Freezer Refrigerator
GE Hotpoint® HTS18GBS Top Freezer Refrigerator Logo
56 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
