Question about Insignia D400a PC Desktop
Need help w/ethernet connection
I have recently purchased a new modem it is a d-link dcm-202 model. It has either usb or ethernet connection. When I hook up directly to ethernet port on my computer the display lights on modem never come up for ethernet connection. When I try to open the internet it will not start. I did diagnostic connection test and it says there is no connection to check my ethernet cables. I am currently using a d-link 524 router along with this modem. Can you give me tips on what to do. Is it possible that there is something wrong with my computers ethernet or nic card. I recently took it to Best buy and they checked everything on computer they said that nothing is wrong with it. Please help
  • 31 Answers
Re: need help w/ethernet connection
Do this go to start >> then run , type >> inetwiz << then tell it to connect using my local area network , tell it to automatically discovery of proxy , then click next, no to setup email address, "you can do later if want to" then click finish and reboot computer
then try opening internet explorer , make sure if you have a firewall "you have to allow access to internet when asked "
Let me know if that got you fixed or not
Posted on Nov 24, 2007
0 characters
3 Points
Can't connect to the internet with ethernet cable or wireless
ethernet jack may be fried.. Go to device manager and see if its disabled or non existant.
Jun 05, 2014 | HP Pavilion m7480n (882780389410) PC...
I have a Dell dimension 350 pc with just a modem connection for a phone line. I just got cable installed which has the ethernet hookup. i would like to still use my 350 with win. 98 if i can. how can i...
Does your cable modem have wireless internet? If so, you can buy a Netgear wireless usb port adapter for about $20 and use that to connect wirelessly to the internet. Your pc has usb port connections - right? (Usb port looks like a rectangle)
If you don't want to use a wireless connection you can purchase a cable modem with a usb connection for about $65. You run the ethernet cable to the modem and then a usb cable from the modem to your pc.
If you have a serial cable connection on your pc (looks like a round circle with tiny metal pins in it) you can buy a gender changer and convert that to usb (in case you dont have a usb connection or need another one). You can buy one for about $11.
You can buy an I/O Gear bluetooth usb adapter for $13 and pick up the internet via bluetooth by putting it in your usb port but I'm unsure how well it would work with Win 98.
If you have another pc that has an ethernet connection you could use good old fashioned bi directional printer cable and network both computers together. You may need to upgrade to win xp for networking capabilities.
Mar 26, 2012 | Dell Dimension PC Desktops
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
I have a Siemens 4200 ethernet/USB ADSL modem on a machine running Windows XP. If I switch to a new machine with Windows 7 64-bit, will I need a new driver for the modem?
If its connected via ethernet you may not need an updated driver of the modem but and updated driver of your LAN card. If its connected via USB then yup try the manufacturers website for the modem divers
Oct 26, 2009 | PC Desktops
I had a lightning strike now my RZ26G wont connect to the internet. Verizon said to get a new ethernet card....i dont see one --- help how can i get back on the internet?
The ethernet card is embedded in the motherboard on this model,If you have a vacant slot on the motherboard you can install a new one there.any brand should do.
Good luck
Oct 22, 2009 | Sony VAIO Digital Studio PCV-RZ26G PC...
Can i connect usb and ethernet at same time with siemens 4200 ?
I did not know you could do it either, but I never tried. I can see an instant work around...make them both ethernet. You surely have more than one RJ46 connection in the modem/router. I figure you had the one closest to the modem was the USB and the one further away way the ethernet cable. So like I said, they probably supplied you with a short e cable so just plug that in. Assuming of course you have an eithernet adapter in the computer closest to the modem.
Try one thing first- plug them in the way you always did, unplug the modem for a minute and plug it back in and see if it detects them the way you had it set up...reboot each of the computers after that...if it is gonna work...this is the way.
Hope this helps Tim, please leave rating, thank you kindly
May 07, 2009 | PC Desktops
I have 2 computers. I can connect to the internet wirelessly with the XP one through a Netgear router. My HP Touchsmart,Vista Home Premium, purchased recently,will connect through an Ethernet cable, but...
Are you sure that your PC has a built in wireless function and not just a regular modem ??
If you just have a modem you will need to purchase a USB wireless interface the link below will take you to one perfectly compatible with your router.
Good luck ;)
Dec 02, 2008 | HP PC Desktops
I am trying to install a cable modem with usb and ethernet connections on a windows xp computer.
Well there are 2 ways
via Ethernet
1.) connect the ethernet from the modem to the ethernet of the computer via the cable provided and thats should basically setup and give you an ip automatically
Via Usb
2.) install the drivers that came on a cd with the model
2.) follow the onscreen instructions and connect the modem via the usb cable when it tells you to
3.) when setup is complete it will create a connect icon for you, just run it to connect
Jul 14, 2008 | PC Desktops
D-link DCM-202: no response from the Ethernet port after switch the cable outlet.
you need to configure first the router to work in your network or pc. If your router have a cd driver run the cd in follow the instruction how to setup or configure the d-link router
Apr 16, 2008 | PC Desktops
NIC too close to USB port?
Hi Antatg,
Go into your bios and make sure all your USB option are enabled, specially Enable USB for legacy devices, and check to make sure you NIC is enables. Hope that helps!
Good Luck!
Jan 07, 2008 | Dell Dimension 1100 PC Desktop
Insignia D400a PC Desktop Logo
158 people viewed this question
Top Insignia PC Desktops Experts
Michael Thomas
Michael Thomas
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Are you an Insignia PC Desktop Expert? Answer questions, earn points and help others
