In laptop
right click on date and time showing at pannel
select adjust date and time then
change date and time then
change what u want
then ok
and lastly apply...
For Windows 10 following these steps to change the time and date:
1. Right click on the time (Normally at the bottom right-most corner of your screen, on your start bar)
2. Select Adjust date/time
3. Press Change (Button under Change date and time text)
4. Set the time/date, and press Change
You can also change your timezone, daylight savings and automatic internet vs manual time on that setting page.
Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
The Date and Time dialog box appears.
Click the Change Date and Time button.
The Date and Time Settings dialog box appears.
Enter a new time in the Time field.
You can also use the up and down arrows next to that field to change the time.
If you wish, click on a new date in the calendar display and then click OK.
You can also change the time zone, if necessary.
Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Click on time section of your start bar (bottom right of screen). Then choose adjust time and date settings.. Following on screen setups to change it over to correct date and time..
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings. Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
Press the Function key, 6222291, Yes. When the date appears, use the asterisk (*) and pound sign (#) to change the month and to change AM or PM, and use the keypad to change the date, month, and time.
Press Yes Function when you've got it set and want to save it.
What do you mean it "does not change"? Have you tried to change them using the Control Panel applet, or by clicking on the time in the taskbar and trying to change it there? Or, do you mean the date and time is not incrementing at all while watching the time?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
