Heating & Cooling Logo
How do I set the indoor temperature - Heating & Cooling
Daikin unit won't turn off when temp is reach
The Fan of the indoor unit is not supposed to turn off when the indoor Temp reaches the set temperature, but the indoor ambient sensor tells the outdoor unit that that's enough. Then, the outdoor unit minimizes the sound of the compressor. It is the normal operation of the Inverters. The Indoor motor fan doesn't turn off until you turn off the unit.
My acurite 00509 has stopped giving me the correct temp reading. I've put another temp gauge next to it and acurite shows 78* and my othergauge shows 72*. Do I need to return it or what ? Thanks
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
What does error code LF mean in a PTAC unit model #PTH093B35AM?? Several of our units are doing this, they run but won't put out any heat? Please help!!
If there are no active failures or lockouts, the display will show a double dash, "- -". If there is a code listed, see the unit "Diagnostic Codes" chart for a list of definitions. Error Codes Problem FP Freeze Protection Engaged. The room temperature measured by the wireless remote thermostat or indoor ambient thermistor active sensor falls below 40°F. No Action required. This setting will disengage when the room temperature rises above 43°F. Fd Front Desk switch is closed. All outputs are switched off. Open front desk switch to allow occupant unit operation. Eo Un-Configured Service Board - All operation held awaiting configuration. Enter Configuration Menu and set "C3" to "C" for coolers with electric heat or "H" for heat pumps. EH Emergency Hydronic Engaged. The EHH switch is closed. Compressor is switched off. Open front emergency hydronic switch to allow occupant unit operation. LS Load Shedding Engaged. The LS switch is closed. Compressor and Electric heat is switched off. Open load shedding switch to allow occupant unit operation. On Control is configured to respond to a wired thermostat. No action if a wired thermostat is being used. Otherwise, see Configuration Settings. oP Open Door Lockout (DS1 & DS2 open; wireless). Close Room Door. Unit will not condition space with door open. nP Window Switch Lockout - (LS & INN open). Close Room Door or Window. Unit will not condition space with door or window open. HP Heat Sentinel - (WIAT > u3). No action required. This setting will disengage when the room temperature falls. Ur Un-Rented Status (EHH & INN or wireless). Front Desk needs to set to Rented mode (if applicable). F1 Indoor Ambient Thermistor reads outside the range -20°F to 200°F & the wireless thermostat is not communicating to the unit control or Indoor Ambient Thermistor (IAT) without a wireless remote thermostat reads outside the range -20°F to 200°F. Replace black Indoor Ambient Thermistor or Wireless Remote Thermostat. F2 Wireless Remote Thermostat failure. Replace Wireless Thermostat. F3 Indoor Ambient Thermistor reads outside the range -20°F to 200°F. Replace black Indoor Ambient Thermistor. F4 Indoor Coil Thermistor either above or below operating tolerances. Replace Red Indoor Coil Thermistor. F5 Wireless Thermostat failure. Attempt to rebind Wireless Thermostat or Replace Wireless Thermostat. F6 Indoor Discharge Thermistor either above or below operating tolerances. Replace Yellow Indoor Discharge Thermistor. Fb Low Remote Battery Warning. Replace Batteries in Wireless Devices. H1 High Voltage Protection engaged. Power supply voltage is to high. Check for incoming power at correct voltage. br Brown Out Protection engaged. Power was lost or voltage is low. Check for incoming power at correct voltage. L6 Discharge Air Too Hot. Clean Filter or Remove Air Blockage. LC Outdoor Coil Thermistor temperature high. Clean Condenser Coils, Check Fan for fault. Code will reset after cleaning. C2 Indoor Air Recirculation. Large delta between thermostat and return. Clean Filter or Remove Air Blockage or Close Vent Door or Improve indoor to outdoor seal. C5 Outdoor Coil temperature too high for outdoor ambient temperature. Check for Blocked Outdoor Air or Clean Coil. C1 Indoor Coil is freezing up. Clean filter, Check for fan and blower operation, Check for Refrigerant loss or Restricted capillary tube. C3 Indoor Coil is freezing up. Clean filter, Check for fan and blower operation, Check for Refrigerant loss or Restricted capillary tube. C4 Indoor Coil froze up. Clean filter, Check for fan and blower operation, Check for Refrigerant loss or Restricted capillary tube. C6 Poor Unit Performance. Check for blower motor, compressor, or electric heat operation. C7 Indoor Freezing Lockout (ICT - IAT > 20) +10 Min. Clean filter, Check for fan and blower operation, Check for Refrigerant loss or Restricted capillary tube.
How to set up taylor `model 1731
  • Indoor (32°-122°F/0°-50°C) and outdoor (-4°-140°F/-20°-60°C) temperatures. Lower outdoor temperatures achievable with lithium batteries; Indoor and outdoor humidity. Includes temperature and humidity trend indicators; Daily min/max recall for temperature and humidity. Features a calendar and clock with alarm; The wireless remote sensor transmits up to 200 ft. The base station and wireless remote require 2 AAA batteries each, not include. If you want essay related topic you can go for custom essay writing service will get better result.
New Generation Custom Essay Writing Service with Intelligence EssayCaptains
My Stirling Reverse cycle split system has an Error code E2 and won't heat or cool.
That means
"Fault of the indoor pipe temperature sensor
- set the temperature manually and call for
service."
So it isn't something you can fix yourself, but you may be able to vary the temp manually by the remote or the indoor unit front panel.
My dometic roof air works fine in the daytime but at night it shuts down and try to restart on and on others have said they replaced the stat and still the same problem,any other ideas
Change the automatic temperature detection settings. Many of these Dometic systems have an automatic indoor outdoor temperature gauge that determines when it shuts off. This is separate from the normal thermostat. When the outdoor temperature reaches close to the indoor set temperature the unit shuts off.
1helpful
Haier A/C CPR10XC7-L
The Haier ESA410J-L is part of the air conditioner test program at Consumer Reports. In our lab tests, air conditioner models like the ESA410J-L are rated on multiple criteria, such as those listed below.
Comfort:This is how well temperature and humidity are controlled at the low-cool setting. The best performers held temperatures to within one-and-a-half degrees of the setpoint.
Indoor noise low:This judgment of indoor noise at the low-cool setting combines an objective measurement of noise level using a decibel meter with a subjective assessment of noise quality (how annoying or grating the particular sounds were).
Indoor noise high:This judgment of indoor noise at the high-cool setting combines an objective measurement of noise level using a decibel meter with a subjective assessment of noise quality (how annoying or grating the particular sounds were).
My aircon unit turns on runs for a minute then indoor and outdoor unit switch off
If this is a LG Airconditioning unit.
It has reached the set parmeter of the safety switch point.
1 The unit could be running on too low refrigerant charge and cuts out on low temperature on the indoor unit coil (-5°C longer that 30sec switch off)
2 The unit might be drawing to much current, to much refrigerant, cutting out on high pressure.
Check the refrigerant charge and check the indoor pipe temperature thermister (calibrated at 5kΩ @ 25°C)
2answers
Need to know if indoor unit fan shuts off at desired temperature
Check your operating instructions and see if indoor fan unit has an "auto" feature that allows the fan to run only when the outdoor unit is running. Allowing the indoor fan to run constantly will provide for better air circulation and less stagnation but will use more energy.
Top Heating & Cooling Experts
Paul Carew
john h
