Question about Kenmore 98702 Stacked Washer/Dryer
RRemoving the washer starter dial
I trying to instgall a new washer timer and am unable to proceed as I can't get the washer switch dial off of the old timer so I can remove the cover. The other dials on the face came off easily enough but if I pull any harder I think I'm going to bust the knobs. Is there any procedure to remove the dial on the timer other than just pullioing it off? Also, at the exposed stem on the old timer doesn't look exactly like the stem on the new timer. The old one appears to have a black plastic sleeve over the white plastic stem. Any advice? I don't want to go any farther as I may make the machine completely unusable. I can manually put the washer throuig it's cycles by advaqncing the dial manually. Thanks.
  • 447 Answers
Yes, stop pulling on it. Axcess the rear of the timer there will be a smaller hole with a black piece of plastic inside where the knob shaft would be if it went all the way through. use needle nose pliers to grab the plastic piece and pull out. it is easier if the knob is pushed in is gets recessed a little more when you pull out the knob. The new timer comes with a new plastic piec pull it out then push back in to lock on the knob again.
Posted on Nov 24, 2007
The washing cycle does no proceed automatically however it does so when the dial is manually advanced. What could be the problem and how to sort it?
Sounds like the drive inside the timer switch. There is a timer motor that causes the timer switch to progress through the stages. When you manually progress the timer, it is physically turned to the next position and the switches all work as designed; it's just that the motor is incapable of doing that job for you as it should.
You need a new timer.
Mar 19, 2011 | Dishwashers
Washing machine circular timer switch stops with load of wash and water inside during the first cycle; circular timer dial also stops moving clockwise. My guess is a defective motor/timer - are they all...
If you are able to advance the timer and get the machine to run and finish the cycle, then yes the timer is your most likely culprit, and yes the timer motor and timer are all one piece.
However if it does not complete the cycle and you are unable to drain the water out, your problem could be with the lid switch assembly, not the timer. Check the switch by looking for a tab on the right side of the lid that would (when the lid is closed) contact the switch mounted under the top of the cabinet. you should hear an audible click when the switch is depressed.
If you find it is the switch, please let me know and I will give you instructions on how to replace it.
Oct 07, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have an older Hotpoint topload washer that the dial just spins. I am unable to set a wash cycle now. The dial is pulled out to stop the wash cycle, pushed in to start and to select a cycle. Can the dial...
HI, this timer mechanism is damaged, and i recommend the replacement of this defective timer control module asap. it can be accessed by removing the cover that is located behind the control panel. the timer is screwed onto the panel from the backside.
replacing this timer control module will correct this issue.
Sep 18, 2009 | Washing Machines
Washer dial problem on whirlpool LSB6000PQ
HI, This will occur when the timer mechinism(washer dial) has failed. The main cause of this type of failure will be timer motor breakdown. The timer motor is essential to the sequential balance of the cycle that is selected. If it is unable to rotate the dial properly, it will not allow the unit to operate correctly.
Replacing the timer module will correct this issue you are experiencing at this time.
Sep 11, 2009 | Whirlpool LSB6000PQ Top Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Dec 09, 2008 | Indesit W 123 Front Load Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
When switched on with a load in it works through the first setting, then the dial just keeps clicking around to the next setting repeating over and over. the only way i stopped this was to switch the power...
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Nov 06, 2008 | Washing Machines
Frigidaire gallery washer
Do you mean that after it fills up with water you have to advance the dial for it to start working?if that is so Check the water level switch.Otherwise you may have aproblem with the timer.
Please rate this solution
Sep 24, 2008 | Frigidaire GLTR1670A Front Load Washer
Peace Friend,
ngafm At your service!
one way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
To do the timer get an authorized tech!
You may spend money on the timer and be wrong!!!!!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
Sep 03, 2008 | Kenmore Elite 45986 Front Load Washer
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
269 people viewed this question
Sal De
 Brian Main
Brian Main
