SOURCE: Black spot on lower part of screen.
Sounds like the LCD is damaged, it's commonly called a bruise. It can only happen when too much force is applied to the screen causing irreparable damage to the LCD crystals, causing them appear darker than the rest.
There is a picture here on the second post down.
SOURCE: Black spot on picture
My Nikon was having the same problem with the stationary black spot. I used a can of Dust Off ( the original compressed gas duster). I just removed the lens and held the camera upside down (lens facing the floor) and blew my compressed air inside and my black spot disappeared. Just a thought you might like to know !! Good luck.
SOURCE: lcd screen has black spot inside, outside fine, takes pictures
you should replace the lcd screen from an authorized service center. or you can buy the lcd screen alone from ebay and find someone to replace it .remember
never open the camera unless you know very well how to replace it.thanks for using fixya. please dont forget to rate my solution
SOURCE: Sony DSC-T1 screen is black. Does not recognize
There may be the issue with the CCD (Image Sensor Device) of the Camera. This is a known issue with this Camera.
Refer this article to confirm this:
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Check whether the LCD screen of the Camera looks similar as given on the page.
If yes, click
on the "Yes" button at the end of the page to create an online Repair
Request for sending the Camera to the Sony Factory Service Center.
SOURCE: round black spot in middle of the picture/screen
Hi :-)
The round blotch your seeing on the screen is the melting of an acrylic lens inside the light engine. Its a design flaw which unfortunately Infocus will not stand behind. To fix this problem requires opening the light engine and putting an equivalent lens in place. This task is very involved, but this problem is repairable and you need a glass smith to cut the right size lens from the original.
