Question about Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Battery
I purchased brand new Garmin StreetPilot C330 GPS in September 2007. I feel I need a new battery as it does not hold the charge too long. Can you please advice me what kind of battery I need , where will I find it and what's teh model number of the battery it uses. I also need step by step directions how to replace it. Thanks !
  • 10 more comments
  • Anonymous Nov 25, 2007
    StreetPilot C330 will shut down during operation for no reason and/or will freeze during operation. Updated the software on the device which appeared to correct the problem; however, the problem is back after about 2-3 months worth of problem free operation.
  • coopshaw Nov 27, 2007
    My Garmin will not turn on either alone or plugged into the car adapter
  • Anonymous Nov 28, 2007
    I get the message "low battery" when I'm driving a short time although immediately before when charging the battery via the computer, the message was Charging complete.
  • Eclipse586 Dec 21, 2007
    A friend has the Garmin C330, and the battery does not work, but the unit still works when plugged into the car via cigarette lighter adapter. I am an electronics Technician, so I told her I would have a look at it to see if it can be fixed.
    The unit is only one year old, The battery stropped working at 6 months of use.
    Upon disassembly and examination of the internals of the unit, I have come to the following conclusions:
    1. The battery is a special Lithium Polymer battery, and is NOT a standard sized battery like a "AA" Sized battery. It must be a special type of battery available (maybe) only to electronics manufacturers, or maybe only to Garmin. This would not be unusual, as it would force you to return the unit to Garmin for repair.
    2. The unit says it is charging the battery when its plugged in, but never takes a charge.
    3. The battery has a special switch or "thermal fuse" built into it and shrink wrapped to the battery that opens or "blows" when shorted or when the battery overheats from charging.
    4. Either the curcuit board that houses the display has a "pico fuse", which is a tiny fuse smaller than a grain of rice, that is blown, and this is the circuit that controls the battery charging that is not working - OR - the thermal fuse on the battery itself is blown, either way you get a battery that will not take a charge. The charging circuit is blown or the battery is bad so the battery thermal switch blew out, either way its a manufacturing or design defect.
    5. The cigarette lighter adapter that I was given along with the unit is a type I have seen before at work, it has a VERY LARGE metal end on it, too large in my opinion to do an effective job of powering ANYTHING without the possability of shorting itself out inside of the socket it is plugged into. This also may cause the GPS to short out internally if you blow the fuse located inside the plug itself while you plug it into the lighter socket. The voltage crossing, and the surge that blows the fuse could easily damage the unit itself.
    I myself cut these lighter adaptors off and throw them away anytime I find them on a device that will be plugged into a cigarette lighter, such as a GPS unit, Video Display, DVD Player, in car Portable Entertainment systems, Etc.
    I install a brand new plug of a different design that does not have a hot end the size of a quarter that is supposed to make contact with the hot wire inside a cigarette lighter socket that is half the size of a pencil eraser. It has an internal fuse just like the units that come with the GPS and other electronics devices, but only has a SMALL button on the end, this type of plug is not prone to shorting like the big honking one from the Garmin that will short out just by wiggling it or inserting it even a small angle into the lighter socket.
    I think the design, and the device itself is defective. Write a letter to Garmin asking for a resolution to this problem, and also send a copy to the Better Buisness Bureau, and the Consumer Product Protection Agency. Either they will (Garmin) will replace the unit, or will be forced to issue a recall and replace the unit, especially if enough people complain to the right people in Washington. Either way, it is a problem only Garmin can fix.
  • Anonymous Mar 02, 2008
    My Garmin c330 will not hold a chrage. How do I replace the battery?
  • jmatthys Jun 13, 2008
    My GPS turns on for a brief second and then shuts off. I've reset it,but it does not resolve.
  • dubbiesma Jun 15, 2008
    I have the same problem...it turn on for a second, then turns itself off.
  • jcarruda1 Aug 05, 2008
    unit will not turn on and i can't find where the battery is.
  • meryannp85 Aug 26, 2008
    I was driving and the gps just turn off. Now it does not want to turn on. I think is the battery, and that it hold to much heat. What can i do to fix it? Where is the battery?
  • Anonymous Sep 02, 2008
    Battery is dead. Alos purchased in September of 2007 and it no longer takes a charge from the car.
  • Anonymous Dec 06, 2008
    what battery do I need to get for replacement, it will not stay on.
  • navore1960 Jan 05, 2009
    unit worked fine then went blank. Will not turn even when plugged in. Fuse is good in the cig. lighter charger. Will not charge when plugged into computer either. Bought in June 2007. Seems to be a common problem.
Pop the face plate off with your thumb nail right uner the Garmin logo. On the right side you will see a reset button. Depress it for 2 seconds. Replace face plate and power back on.
Posted on Jan 30, 2010
I had this problem recenly and it had to do with the cigarette power connector. It wasn't working. When I pluggged the Garmin into my laptop with the special connector to upgrade software, etc. It charged the battery. In my case the fuse and the metal end of the cigarette plug fell out. I imagine the fuse might also blow out. If you can power up the GPS using the USB connector, check the cigarette power connection. Is the metal end still on it? If you unscrew the end and pull out the fuse, it the fuse OK? Replacement connectors can be found on the internet.
Posted on Aug 21, 2008
    New Friend:
How to fix a blown curit on garmin c330
Posted on Dec 18, 2012
Where can I purchase a new battery 3,7V - 1,8Ah for may Garmin C330.
Thanks
Posted on Feb 17, 2010
You cannot replace the battery
Posted on Nov 24, 2007
StreetPilot C330 (010-00401-10) GPS Receiver: I just recently purchased a Garmin GPS system for ...
If there are no power points in your vehicle, you might have to purchase a battery-operated powerpack and plug the GPS into that via a USB/AC adapter.
May 18, 2010 | Garmin StreetPilot C330 GPS Receiver
Screen says low battery, then goes blank. can I get a new battery?
Yes, you can replace the battery. Please view video at link; http://www.videojug.com/film/how-to-replace-your-garmin-street-pilot-c330-battery-2
And also see link to purchase battery.
http://www.newpower99.com/Battery_for_Garmin_StreetPilot_c330_p/garmin%20streetpilot%20c330.htm
Please let me know if it helps.
Thanks
Apr 26, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin Streetpilot battery no longer works
just bought a battery for my Garmin 330 C off ebay for around 20 and put it in myself, not a bit undertaking although you need a battery operated soldering device to make it easy.
Mar 31, 2009 | Garmin StreetPilot C330 GPS Receiver
How to install new battery in Garmin Streetpilot c330
After you remove the bezel on the front you will see 4 small phillips head screws, remove those.... While opening, pay close attention to how the built in antenna comes out, it will make it easier when putting it back together,
Nov 29, 2008 | Garmin StreetPilot C330 GPS Receiver
My garmin gps will not charge and it will not stay on.
Your battery inside the GPS is most likely either defective, or has been overcharged, creating an effect where the dry cells inside the battery are swelled and no longer work as they are made to. The only way to fix this is to send the GPS to service and have a new battery installed. to avoid having this happen again, don't leave any device with a rechargeable battery plugged in longer than it needs to be(IE after it has fully charged).
Oct 07, 2008 | Garmin GPS
Remove front bezel by lifting just under the GARMIN name. Remove the 4 outer screws. Gently pull apart. Keep in mind the orientation of the antenna as it's a bit tricky to put back. The battery is mounted between the two speakers.
It's a round cylinder item attached to the main board by a plug. Problem is this plug also houses the connection to the speakers. If you are good at rewiring, cut the battery leads and reconnect them to the new battery. Not sure where to get the battery though.
When putting back the antenna, keep note of the tabs. The lower one remains on the outside of the shelf guide, and the upper one is on the inside of the shelf guide.b0d8aad.jpga47c0e7.jpg2a171e3.jpg
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
Purchase an external antenna from Best Buy or on line from Garmin.
Jun 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 problems
my c330 shuts off after 3 seconds and then wont start back up . on battery or adapter
Apr 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS--Battery
The batteries on the units are not meant to be serviced by the unit. If you are not familiar with taking it apart, you may damage internal components in trying. If the unit needs service, it is best to return it to Garmin and let them take care of the repairs. As far as the battery not holding the charge, if you have not done so, charge the unit on the computer for a few hours. This sometimes helps.
Nov 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
966 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
