Question about Diehl Hardware & Accessories
I'm using a Diehl DC timer, model Typ884.1K Is there a DIN rail moutning kit for it? Thanks, Kevin
2 Suggested Answers
SOURCE: Need to replace a Diehl Typ 880, T85 120V 60Hz
The Type 880 is the exact replacement. Still available at most pool supply outlets.
Posted on Feb 10, 2011
How to connect a pool timer with a sul 181 h
Din rail timers and wiring appear following link:
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 01, 2015 | Hardware & Accessories
How to program CLS Q 31 D TIMER
CLS Q 31 D timer is ordinary 50-60 Hz 24-hour din-rail analog timer; rated 15 amp, operating voltage 230v with power reserve and 30 minute time increments.
15 amp safe max is 12 amp x 230V = 2760 watts. Use line fuse to protect timer from overload. Use contactor for heavy-amp loads and 3-phase loads.
Copy following links for setting analog timers and wiring din rail timers
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-program-Hagar-timer.html
Add a comment and describe application for this timer
May 18, 2013 | Hardware & Accessories
How do i use the diehl m111-8 timer and how to set it
1) Copy following link for Diehl timer manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#dial
2) Model number given does not match known product.
Google search shows fixya on first page result, implying there is no information on this model number timer.
Add comment and describe timer in detail.
Feb 17, 2013 | Hardware & Accessories
I need operating instructions for a wylex timer
There is no instruction manual for Wylex timers.
However the Wylex sell sheet appears to show generic din rail mounted timers.
Since these timers are made by other companies, and then sold by various companies, and then the models change rapidly, the best course of action is as follows:
1) Re-post question with clear and detailed description of timer buttons, and say what the timer controls.
2) Google image search for 1 and 2 channel timers to find same-similar timer.
3) Most timers have similar programming steps and once you find timer with same buttons, then that timer manual can be used to program unidentified timer.
4) Open following links to find din-rail timers that might match:
http://waterheatertimer.org/Hagar-timers-and-manuals.html
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DIN
Jun 23, 2012 | Hardware & Accessories
As i saw the timer i wonder what is the use of that adjust around the timer..as i saw the model of the timer
Question doesn't make sense in english.
For foreign translation, you can use google translate.
http://translate.google.com/
Deihl analog timer has segments around edge of timer dial.
Segments can be set in or out.
Use finger to set segments one way or the other way.
The dial rotates a full circle each day.
The segments move small switch.
The switch turns light on and off.
http://waterheatertimer.org/images/Diehl-880-segments-A-.jpg
Open following link.
Sep 04, 2011 | Diehl TIME CLOCK- 120V 24 HOUR
Manual for diehl multi-timer typ 181-5
Timer number does not match Diehl timer numbers
1) Diehl timers and manuals appear on following links:
http://www.borggeneral.com/
http://www.borggeneral.com/diehl-control-timers.html
2) Add a comment with in-focus photo of timer posted on flicker for possible identification and more help.
Jul 19, 2011 | Hardware & Accessories
HOW I INSTAL ,CONNECT SWITCH TIMER TE502 ? IT
Wiring diagram shows on side of timer and looks same as to following illustration:
http://waterheatertimer.org/images/NO-NC-timer-200.jpg
For more complicated illustration showing din rail and modular timer wiring variations:
http://waterheatertimer.org/images/NO-NC-timer.jpg
With din rail timers, the power connects to screw terminals 1 and 2 and this will run the clock and relay.
The TE502 image is bad, and I can't see wiring diagram exactly.
It appears that terminal 4 is common. This is typical for din rail timers.
Put Hot lead to terminal 4.
Terminal 3 appears to be the NO terminal, so put wire going to Load to terminal 3.
Jun 20, 2011 | Electrical Supplies
Diehl Timer 4 pin wiring
well..the timer is used in a variety of dryers. which model is this one going to be installed in?
Oct 15, 2008 | Dryers
Hardware & Accessories Logo
179 people viewed this question
Top Diehl Hardware & Accessories Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Gene Haynes
Are you a Diehl Hardware and Accessory Expert? Answer questions, earn points and help others
