I dont have the manuel for the tv so I need directions on how to go about setting it up to work with the cable channel we have here. The tv is a Craig Model CLC 501. Can you tell me how to go about doing this?
SOURCE: Setting the channels
You can download the manual from the link below: http://safemanuals.com/download_94794.htm Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: dont know how to get cable channels , i just get local channels.
Hello.
It sounds like you need to change a setting before running the auto or channel scan. On the same menu screen that has the option for running the channel scan, you should see a setting that has next to it the word "AIR" or "ANTENNA". If this isn't changed to "CABLE" or "CATV" then the TV will only scan for a limited number of channels because it assumes you have an antenna hooked up to it instead of a cable line. This is the same for all TVs. Anytime someone runs a channel scan on ANY TV and they only pick up a limited number of channels, they need to change the setting I've described. And remember, it will be on the same menu screen that you go to in order to run the channel scan.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
P.S. On some TVs, autoscan is called autoprogram.
SOURCE: I can only get 2 channels on my TV hooked to Cable
Please do the Auto Channel Program once again and let me know.
SOURCE: Will not set tv channel to 3...keeps telling me to please run channel auto scan
You can do it manaly.
