I am gettig a mesage that the carrier is jam how do i unjam it
  • 555 Answers
Hello please try to check your printer has a paper or some object that makes it jam. You can open the door at the back if it has a door to see any object that makes your printer jam.
thanks
Posted on Jul 30, 2009
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
Can't get carrier jam unjammed
Try to remove the cartridges from your printer. While the cover is open, check for any obstructions in the cartridge carrier path. Check the encoder strip (transparent strip) and make sure it's still in its place and not dislodged or loose. Close the cover. Unplug and replug your printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Try to print again. If problem continues, please contact Lexmark technical support for assistance. Thanks.
Feb 13, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have a hitachi NR 83A2 framing nailer with a jammed firing pin. How do I unjam it? I have the exploded diagram. thx. andrea
by jammed I take it you mean a nail has jammed the driver? If that is the case there is really no easy to unjam it. But unplug the air hose and turn tool upside down and wearing safety glasses and gloves you can try and take a punch smaller than the nose piece and try hitting the driver to unjam nail. If it is another problem please let me know and I will try and help more.. Sometimes we used to have to remove the nose and heat and it goes on but hopefully it is not that bad
Feb 03, 2011 | Hitachi Air Tools & Compressors
Arrow T50P gun jammed - how do you unjam it?
Buu a different brand or model this one is junk and should be taken off the shelf
Feb 06, 2010 | Arrow T50P ARROW STAPLE GUN
I installed a new cartridge and the printer CARRIER JAMMED
Jam means there is somthing stuck at the exit of the paper, it should be paper stucking there, could be small you donot recognize it. check the enterance and the exit of papers place .
Thanks for using Fixya
Oct 12, 2009 | Dell 924 All-in-One InkJet Printer
HP Officejet 6310 All in One - small paper being faxed is jammed. How do I unjam the paper?
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Oct 08, 2009 | HP Officejet 6310 All-In-One InkJet...
I'm trying to replace black color cartridge, but get an error message: carrier jam How do I unjam it? Already did the unplug- check for paper jam and replug...no luck!
Remove all paper...(inspect closely for paper jammed way inside!)
also remove both ink cartriges, reinsert them one at a time carefully and properly....also double check the number code on the ink
the jam error could be either paper or cartriges confusing the printer. let me know if it works....k
Apr 19, 2009 | Dell 924 All-in-One InkJet Printer
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
924 printer jam
make sure your carrier belt isnt broken
Dec 31, 2007 | Dell 924 All-in-One InkJet Printer
147 people viewed this question
jasbo
jasbo
