SOURCE: Tank full light stays lit.
Under the water bottle is a drain hole,when the bottle overflows water runs down this hole through a pipe to a reservoir behind the condensor unit, there is a float in this reservoir that rises and clicks a switch that activates the full tank light and stops the machine working,
removing the stopper at the rear and emptying the reservior should do the trick,If the float does not go back down due to dirt in the machine the left hand side panel can be removed by taking off the top then the retaining screws,one inside at the top the rest in the back panel,remove the one screw holding the float switch unit and clean the black float.(Make sure it's not plugged in)
SOURCE: self clean light keeps blinking
Hello guindonlm,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with
the easier solution first. In the DCC 1200 there is a filter "stick or
column" in the left rear. Pull it out and remove the clogged carbon
filter(s) that are in there. Shine a light into the receptacle and
remove the debris in the bottom. It is likely that this is causing the
problem with you machine needing to be started on multiple times. See
if this solution works. If it does, you might run 8 cups of water and
4 cups of vinegar through to help decalcify the units plumbing. Do this
once or twice and then rinse with at least one pot run-through of
clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following:
unplug the unit and lay it on its back. You will need a #10 torx
driver (hardware store if you don't have one) to remove the bottom
cover plate. There are 4 torx screws holding it on. When removed, you
will find 2 orange hoses. Carefully attempt to remove the left hose
without splitting. I used a eyeglas screwdriver to loosen it up. If
it splits, just cut off the split and stretch it to reconnect when time
comes. As you look into the hose you will find a little black valve
inside as well a some gunk. Clean it all out with a fine wire as best
you can. Rinse well. Attempt to reconnect the hose back onto the
pipe. Slip the pipe clamp back into place. Replace the cover and
screws and you should be good to go again. This is not as daunting as
it may seem. You can do it. :o) Good luck! If this answer helps,
please leave positive feedback for me. Much appreciated. Regards,
NormanZ
SOURCE: My Cuisinart 12 cup programmable coffee maker will
Hello jimmarsh,
You are right, there is a way to fix this. This is really a common problem with this unit that is fixable.
I recently had this similar problem. If you still have your machine try the following.
without splitting. I used an eyeglass screwdriver to loosen it up. If
NormanZ
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge
counter is already full. Please refer below for the instructions on troubleshooting
your machine.
1. To enter MAINTENANCE Mode: Press
MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the
following:
a. 8 then
press SET
b. 0 then
press SET
3. Using MONO START, just press it until
the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the
following:
a. 2 then
press SET
b. 7 then
press SET
a. 8 then
press SET
b. 3 then
press SET
This is to reset the purge
counter. Then press stop/exit
5. Using arrow up button look for the
following:
a. 0 then
press SET
b. 1 then
press SET (To reset unit)
a. 9 then
press SET
b. 9 then
press SET (To exit Maintenance mode)
SOURCE: Self clean feature on coffee pot
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf. This is the manual of the product
The link below suggests using vinegar and water to remove calcium. Is yours a blinking light or not?
https://www.cuisinart.com/share/pdf/manu...
