Question about HP OfficeJet 6110 All-In-One InkJet Printer
Automatic document feeder will not feed. Tried
Automatic document feeder will not feed. Tried cleaning it with compressed air.
    President:
  • HP Master
  • 1,996 Answers
Check the sensor. (See here)
Take a look at solutions offered here.
Sorry I can't offer much more at the moment, the HP search engine is down for maintenance...
Posted on Jul 30, 2009
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
Canon IR 105 Will Print from Network and Fiery but won't copy
So, the feeder will not pull in the paper, If this is the case, check the throat of the document feeder for foreign objects, (staples, paperclips, post it notes, or signature flags). you can clean the rollers with alcohol, and blow out the document feeder with compressed air. (Computer Duster)
Ed
May 06, 2009 | Canon imageRUNNER C3200 Copier
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Jamming of documents in autmatic feed for scan mode
One way to unjam that would be to take a stiffer plastic or manila folder and insert it slowly into the document feeder and the slowly push it through the feeder until you dislodge the jammed document out of the bottom of the feeder.
That is a common practice in removing jams in the feeder.
Mar 13, 2008 | Office Equipment & Supplies
Document feeder doesn't feed well
Try Cleaning the rollers or separator pad
  1. Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. Close the cover of the automatic document feeder.
If this solve your issue pls let me know, if not ill try to look for another solution for you.
Jan 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
you have to replace it if cleaning doesn't help.
look for the seperation tire or pad if it picks up the paper from the top first then the sep is on the bottom and vice versa. Clean that on really good this is the one that seperates the paper and stops it from feeding more than one sheet.
Oct 21, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
193 people viewed this question
Seeker5211
Seeker5211
