Question about Car Audio & Video
IR headphones are not picking up the signal from Flip down DVD
TView T950DVFD-TN is the dvd player I have in my truck. I oredered a pair of brand new IR headphones and they worked fine for a few weeks. Now like the old pair I have the signal is not being recieved in the headphones. The website for TVIEW does not have the manual for download. HELP
SOURCE: TView headrest dvd player
hi hallow then their is a problem in passing power supply or receiving power supply r some where the connection may lost which unknown to u so please refer it once again and see the battery connected perfectly are not. u explained u r problem very well but such problem can solve by cheaking the instrument practicaly so if still u r problem is not solved its better to consult the expert near to u directly
Posted on Feb 25, 2008
SOURCE: tview dvd
hi i have a nesa 180 in car dvd, i can only get sound through the nesa nhp-1 head phone, can i get sound with out them, also one of my head phones is broken were can i get a replacement.
thanks
Posted on Sep 26, 2008
SOURCE: Tview DVD799TS-BL need manual. Where find it?
http://www.tview.us/manual/DVD799TS-BL-manual.zip
Posted on Apr 18, 2009
  • 1632 Answers
SOURCE: no picture on tview dvd70ts
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
  • 903 Answers
SOURCE: when I put my DVD into my Tview headrest unit, it
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
Posted on Jul 11, 2010
Tview in dash dvd
Let me make sure I understand this. When you have a DVD play in English, you get a buzzing noise in your wireless headphones. But if it plays in Spanish, it sounds fine? Does this occur with every DVD, or just a certain DVD? Have you tried listening to it without the headphones - using car speakers. If so, did you have the same problem? If you can answer those questions for me, I can try to figure out what's wrong here.
Aug 29, 2007 | DHD NTX-8496 Car DVD Player
When I put my DVD into my Tview headrest unit, it runs and runs and runs and then comes up and says no disc
Jul 01, 2010 | T-View TView (DVD1006) In-dash DVD Player...
Trouble w ir headphones
check the batteries in the headphones
Jan 22, 2010 | Audiovox Car Audio & Video
Panasonic car video player
Try to look on Ebay or maybe Google, you can find almost anything now aday. Goodluck.
Mar 07, 2008 | Car Audio & Video
How to use
These are IR headsets. I don't think they will work with a DVD player or Laptop, which usually just support Bluetooth.
Sep 03, 2007 | Myron & Davis AE-21 Headphones
Wireless Headphone not working with my portable DVD player
Firstly, make sure your DVD have built-in IR wireless module so that your headphone can receive the audio signal from your DVD player.
Second, it should be clear which frequency transmitted from your DVD player. Generally speaking, there are two frequency of IR transmitter.One is 2.3MHz/2.8MHz. another is 3.2MHz/3.87MHz. Only emission frequency same as receiver can receive the audio signal.
Jul 02, 2007 | XO Vision Wireless Infrared Stereo...
How do I get audio on my farenheit dvd-15?
Did you try tuning in to FM 88.7, this should pick up dvd audio
Jun 28, 2007 | Farenheit DVD-13 Car DVD Player
MY DMR-EH55 has problems repsonding to the supplied remote control
Firstly, check you do not have bright light shining across the IR sensor.This can degrade the signal to noise ratio of the IR receiver.
Second, check you do not have a noisy mains electricity supply, arcing plug block or running from square wave inverter supply. Either of these can cause problems with IR receiver in the DVD player.
Feb 25, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Remote Sensor
Start a DVD playing, cover the IR sensor on the DVD player with something opaque. Try changing the volume, the player should keep playing. Your TV, surround sound, and DVD player have conflicting IR codes. The DVD player probably does not use a discreet IC to filter the IR sensor, and the processor in the DVD player is having to look at all the IR codes picked up by the IR sensor. Go to Walmart or KMart and buy a new DVD player for $29.00 or stop changing the volume while watching DVDs :) Sorry, there's no real solution that I know of. Paul.
Jan 01, 2007 | Norcent Technologies DP313 DVD Player
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
