Question about Kenmore 22422 Top Load Washer
Washer spins stops to quick like hitting a break
Stops to sudden stop and shkes the whole machine whirlpool series 80
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
CLUTCH IS STICKING, THIS OFTEN HAPPENS AFTER THE MACHINE IS MOVED OR WHEN THE TEMPERATURE CHANGES, YOU MAY RESET IT BY WASHING A HEAVY LOAD OF JEANS, THE WEIGHT WILL MAKE MACHINE HEAVIER AND HELP KEEP IT STEADY AND MAKE THE CLUTCH SLIDE LIKE ITS SUPPOSE TO, AFTER THIS YOU SHOULD BE OK
Posted on Feb 07, 2010
The washing machine makes a heavy, sudden 'klunk' when it stops spinning. It's a Kenmore 70 series, about 15 years old.
This assumes that you have a KENMORE top load, direct drive, neutral drain washers are made Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Jun 19, 2010 | Kenmore Washing Machines
MY Kenmore 80 series washes, agitates,ans spins finr but when the spinning is over as it slows down there is a large thumping noise like its out of ballance or trying to break but slipping.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
Assuming that the springs are OK and that the vibration pads are in place and not worn, (See the Sears diagram or the following Whirlpool Service manual)
the problem points to the brake.
Apr 15, 2010 | Kenmore Washing Machines
Kenmore 80 series washing machine is not agitating
Apr 09, 2010 | Kenmore Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle makes a loud noise when stopping
Assuming that yours is one of these, the washer uses a brake system to stop the basket at the end of the spin cycle.
When re-assembling the washer, make sure that the tabs on the drive tube fit into the slots in the drive block.
If necessary, Whirlpool makes a replacement set of brake shoes for these washers Part # 64232 (see page 14 of the parts list PDF.
Oct 27, 2009 | Kenmore Washing Machines
Top loader series 80 Kenmore doesn't stop after the whole wash cycle, it goes directly to 2nd rinse, then spins again and stops?
Since it does everything else, the problem points to the timer.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers with an extensive troubleshooting section.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
